Results 1 to 6 of 6
- Sep 2013
- 153
February 15th, 2014 03:07 PM #1Hi,
I'm planning to replace my existing spare mag tire to a donut tire to save some space in the trunk. Are there things to consider before doing this? What are the advantage and disadvantage of using a donut tire?
- 52,512
February 15th, 2014 03:12 PM #2donut tires are intended to enable the vehicle to "limp over" to the fixit shop, so's the regular tire can be fixed and re-mounted.
they are smaller than the regular tire, and are thus not as robust. they are not designed for long-term use, but only to enable the car to be driven to the repair center. also, if they are slightly smaller than regular tires, they might adversely affect the car's driveability during extremes, i.e., unbalanced forces might tend to pull the car to the side... they are also not so photogenic..
they were really designed so as not to occupy too much space in the trunk.
my question to you is, do you really need all that extra space that a donut will generate?
might i inquire, what is your car?Last edited by dr. d; February 15th, 2014 at 03:21 PM.
- Mar 2013
- 6,160
- Sep 2013
- 153
February 15th, 2014 05:36 PM #4I have a honda civic 97 car. It has no trunk tray installed and I want to make one from plywood. The thing is, the regular spare tire is overlapping the height of the majority trunk floor space, meaning if I place a trunk tray, it would stick to the spare tire and will leave an uneven fit. That is actually my reason.
- Sep 2013
- 153
February 15th, 2014 05:37 PM #5
February 19th, 2014 10:54 AM #6
Other than what dr. d said, if your ride is a city dweller, with access to a tire shop or a shop that can repair flats, then there's a factor to go for it. If, however, you take your ride on long drives regularly, methinks the chances of needing the spare are bigger and the chances of getting to a tire repair shop are smaller, so the risk becomes greater. Thankfully, I've not had to change a tire while out on a road trip, though I'd think twice about having a small spare that didn't originally come with the car when that far out.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
