Results 11 to 20 of 20
November 1st, 2016 10:09 AM #11
November 1st, 2016 11:21 AM #12
Go with the 20s (use size 275/55R20 tires).
Ride comfort will not vary much as with cars nowadays, its really the suspension design that will dictate the overall comfort. You may feel rough imperfections more but the "tagtag" factor remains pretty much the same as with the stock tires setup.
November 1st, 2016 12:24 PM #13
November 1st, 2016 12:26 PM #14
November 1st, 2016 12:29 PM #15
Thank you all for the inputs. Does the suspensions really dictates the riding comfort? Say, what if I upgrade my suspensions and still with its stock rims, will I notice a big difference in the ride's comfort? Or if I upgrade in a 20's, should I also upgrade the suspensions for comfort? Any recommendation?
Thanks again in advance!
November 1st, 2016 12:41 PM #16
i have an everest titanium. stock tires were 265/50r20 and they were matagtag. i test drove the trend model which has 265/60r18 tires and the ride was way more comfortable. when i changed the tires to 275/55r20 the ride was almost like the everest trend already. note that these 2 models have exactly the same suspension systems, different trim lang. i upgraded to nitto teŕra grappler g1 275/55r20s.
malaki factor din ang tires and tire pressure. with the oem 265/50 kahit 33 psi na ang tire pressure matagtag pa din. with 275/55r20s at 33 psi nabawasan ng malaki yung tagtag. with these very same tires if the inflation pressure is 37 psi dama ko na ang tagtag. if i lower it to 33 psi maganda na di na matagtag. if i lower it even by just 1 psi more, down to 32 psi, swabe na ang ride.
November 1st, 2016 12:48 PM #17
November 1st, 2016 01:00 PM #18
November 1st, 2016 01:25 PM #19
for safety issues, is there is a limit or percentage to follow when changing/upgrading stock wheel and tires para hindi masyado affected speedometer, odometer and brake system?
Sent from my SM-A9100 using Tapatalk
November 1st, 2016 01:26 PM #20
My friends says he got those for 11k per tire which is pretty cheap since the Proxes ST is a high end SUV tire for paved roads. If you could get it at that price, that's great. He got his from Ben's OK in Banawe.
If you wanna go for Nitto, your choices are the Nitto 420S (touring) and Terra Grappler (A/T). The touring tire has a better ride of course. Many SUV owners go for Nittos not because of performance but because of the aesthetics of the tires' tread pattern. A bit pricey though - I would opt for the Toyos if possible. Toyo actually owns Nitto.
The Federal Couragia is a cheaper option (Taiwanese brand) and it also comes in touring, H/T, and A/T variants.
My advice would be to call around the tire shops in your area to check what tires they have available for your size (whether you decide on 265/50R20 or 275/55R20). That way, you can narrow down your options and compare prices. Then read up on the individual reviews of those tires (because brand alone isn't a surefire way to determine the tire's quality) and decide from there which one suits your needs in terms of value for money and performance. [emoji4]
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
