Results 11 to 18 of 18
July 25th, 2016 11:50 PM #11
July 26th, 2016 12:12 AM #12
Personally I would prefer to just get rims of the higher end variant of the Mobilio, than get tiny 15" aftermarket rims.
My general rule is to go 1-2" bigger than stock rims when upgrading. Otherwise parang sayang lang. Of course it's personal preference. Kung nagagandahan ka sa 15" Rota edi go ahead. Importante naman ikaw yung masaya
July 26th, 2016 12:14 AM #13
Sir all mobilio models have 15" AFAIK.
Sent from my D6503 using Tapatalk
July 26th, 2016 12:24 AM #14
Yup. That's the point. Kung same size lang din naman, OEM nalang. Weird talaga for me yung aftermarket na maliit. At least pag OEM na maliit ok lang kasi nga OEM-look naman.
All Mobilios use 185/65 R15 tires too so rims lang talaga papalitan.
Again, different strokes for different folks. I always go for subtle mods for all my cars, some people prefer otherwise.
July 26th, 2016 12:29 AM #15
Ah I see. You called the 15" tiny kasi sir so I assumed you thought high end models have larger wheels. Sorry
July 26th, 2016 06:52 AM #16
I hope you can still accommodate my comments sir. A couple of friends of mine, who used to race cars as a hobby & are verified car nuts, advised me against buying China or Taiwan replica rims. They said there have been numerous instances wherein those rims cracked or shattered. They always recommend Rotas or OEMs (maski surplus). Color na lang ang piliin mo. One popular color nowadays is Gun metallic. It does a good job of hiding scratches. As for your tires, your 185/65/15s have a diameter of 621 mm. For a better look & handling, it will be better to get a set that is a little wider, say 195 or 205 width. Just be mindful that you are within 3% of 621mm.
July 26th, 2016 07:03 AM #17
BTW, as for the rim size, if your route takes you to areas that have lots of potholes, better stick to 15s. If you will still consider an upgrade, a 16" rim would make a lot of difference as far as looks is concerned & be better than a 17" as far as ride quality is concerned (& will also affect your suspension components).
- Feb 2008
- 24
July 26th, 2016 05:57 PM #18Thank you very much sa mga suggestions and advice ninyo.Ang laking tulong po para sakin na newbie. Most likely mag 16" na lang ako para nmn di saya yung upgrade.I saw oem mags ng latest jazz mukhang ok sya but still searching na babagay sa lunar silver na sasakayan.
I agree on that one. That was also the reason I got silver vehicles. This time however, I decided...
