Results 51 to 60 of 60
March 9th, 2016 11:28 AM #51
- Jun 2012
- 269
March 25th, 2016 11:53 PM #52Pag 20s mga sir, ilan ang allowable na max air pressure pag fully loaded (7 pax) pati roof rack? sabi kasi 30 lang, kaso parang kulang lalo na pa from cavite to bicol. TIA
March 26th, 2016 09:36 AM #53
Pareho tayo bro, but mine is a hatchback, color red. Kung metal rims pa ang nasa auto mo, those are size 14x5j with offset of 43mm. Go with 15x6.5j na lang. Wheel dealers don't sell 16s, straight to 17s. Problem with 17s is that the ride becomes harsh & may shorten suspension life. It might also become an issue, come warranty claims. Take note of the rimwidth also. 7j & above may cause rubbing on the bodywork or suspension parts, depending on the offset of the wheels. BTW, careful din because wheeler dealers will sell you anything. Bahala ka na kung magka problema. Check this out also:arbibles.com/tyre_bible_pg4.html
March 26th, 2016 09:38 AM #54
Pareho tayo bro, but mine is a hatchback, color red. Kung metal rims pa ang nasa auto mo, those are size 14x5j with offset of 43mm. Go with 15x6.5j na lang. Wheel dealers don't sell 16s, straight to 17s. Problem with 17s is that the ride becomes harsh & may shorten suspension life. It might also become an issue, come warranty claims. Take note of the rimwidth also. 7j & above may cause rubbing on the bodywork or suspension parts, depending on the offset of the wheels. BTW, careful din because wheeler dealers will sell you anything. Bahala ka na kung magka problema. Check this out also: carbibles.com/tyre_bible_pg4.html
- Aug 2013
- 475
March 26th, 2016 01:00 PM #55
- Jun 2012
- 269
- Jul 2015
- 9,584
- May 2016
- 5
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
