Results 11 to 15 of 15
- Jun 2004
- 1,311
July 19th, 2007 08:43 PM #12
DIY Painting..
240 grit sand paper
800 grit sand paper
1000 grit sand paper
water
soap
1 lit acrylic thinner
1 qrt acrylic body paint
1/2 qrt epoxy primer w/ catalyst
1/2 qrt top coat
compressor
or
spray paint na acrylic will do basta important yung epoxy primer
1. mas maganda kung kalas pati goma para d mapinturahan
2. kng may tyaga ka, gumamit ka ng Paint Stripper to stip all paint ng mags, mejo matrabaho ito. repeat if necessary until all metal are shown.
3. use steel brush to clean or 240 grit of sand paper or even an old toothbrush will help.
4. pwede rin i-sand paper mo nalang with water and soap if the paint is still in good condition. use 800 grit of sandpaper
5. wash with soap and dry. as in dry na dry
6. mask all the parts na ayaw mo mapinturahan (lip or some areas of the spokes or the tires kng d nakalas)
7. spray 1st with epoxy primer until it cover up all areas. let dry for at least more than 1 hour para tumigas
8. for best result, spray thin coats then repeat para maiwasan ang smuges
9. sand with 1000 grit sand paper with water and soap para makinis then wash and dry...
10. spray with body color until it cover up all areas.. spray thin coats for best results.. let dry then sand with 1000 grit sand paper then repeat painting with thin coats..allow to dry for 1 hr.
11. spray all painted areas with top coat under the sun for better results then let dry overnight.
I hope maka tulong sa inyo to..
April 18th, 2011 12:45 AM #15
Daming issue ng SU7:grin:
Xiaomi E-Car
