Results 1 to 2 of 2
March 20th, 2015 10:02 PM #1
Greetings everyone! Newbie here at gusto ko sanang humingi sainyo ng advice.
I was wondering kung ano ba ang maximum tire size na pwedeng magkasya sa stock 2005 Hilux 3.0 D-4D without doing any lifting? Plano ko kasing i-upgrade na ang kanyang mga tires from the stock 255/70/R15 Bridgestone Dueler H/T to an all-terrain (A/T) or if possible, mud tires (M/T).
I've been doing some research at base sa mga ilang nabasa ko ang 31/10.5/R15 ay big enough na daw magkasya without causing any rubbing in the fenders/wheel arch/mudflaps and anything higher will definitely cause rubbing.
I hope someone here could confirm this, since due to budget constrains ay gusto ko lang sanang mapa-laki ang tires ng aming Hilux ng hindi na gagastos pa ng extra sa pa-lift. Kung sakaling walang problema ang size na ito, ano namang other tire brands ang recommended ninyo?
Thanks guys in advance. Much appreciated!
March 21st, 2015 01:07 AM #2
As I remember, do not go beyond 3% more than the actual diameter of the stock tires. Google the outer diameter of your stock tire.
