Results 11 to 18 of 18
- Apr 2004
- 653
July 30th, 2009 06:31 PM #11Many thanks sirs av8or5 & niky..! my truck is a strada GLX model..so no need for rim replacement..wheew..umandar agad pagkakuripot ko hehe..
ma'm aejay thanks also for the inputs..I know for a goodyear 15"(radius ata) tire replacement costed me p2100 each ata for my ex car..how much kaya for this 16x245mm tire same stock brand (i forgot) mitsu uses..
July 30th, 2009 07:11 PM #12
July 30th, 2009 08:29 PM #13
If you want Bridgestones (4x2 Strada OEM) the cheapest 245's will set you back around 5K apiece. If you're aiming for a wider look for your tires though, you might be disappointed if you mount them on the 6" rims. Although they'll fit, bulging out na yung sidewalls. They'll look much better on 7"s.
July 30th, 2009 10:12 PM #14
Sir 1 set po iyan. Dati po bumili ako ng mags rin. 6k/set po. 4 rims lang po.
- Apr 2004
- 653
July 30th, 2009 11:35 PM #15thanks for the fresh inputs, gents..! I dont think my conscience can take a 2009 strada truck having bulging tire sidewalls..coming from motion.car chart data, a 4x4, 2.5 variant gets 245mm wide tires with matching rims..seems OK with its stock weight at 120 kilos more than the GLX..but one has to prepare for a low FC ratio..
now for the cost..at p6thou / set x 5 sets = P30K less my stock tires/rims swap of about P20K = P10k..I'm on saving mode now..
- Aug 2009
- 2
August 23rd, 2009 04:49 AM #16question lang po.... if Php 20k and trade in for old rims/tires.... saan po ninyo ikakabit yung bagong tires? just a thought..
- Aug 2010
- 5
August 9th, 2010 01:30 PM #17Buhayin ko lang po itong thread na ito,
I am a newbie regarding automobiles
I just wanna ask kung magkano po kaya ung isang set na 18" = 19" na rims na black. Dami ko kasing nakita sa evangelista na pwesto ng mga bentahan ng rims. Ayaw ko munang magtanong kasi baka lokohin lang ako sa presyo. Magkano po kaya un mga sir?
August 13th, 2010 06:12 PM #18
Magtanong ka. They wont be joking around with you, pero syempre hindi ka muna makikipagtawaran. Wag ka matako.t hehehe
If you have the money, saka ka maghaggle.
