Results 1,941 to 1,950 of 2394
January 21st, 2020 04:21 PM #1941
Yes attractive pricing at 2500 per tire. Kaso nga on my last set, nag-shred (imagine parang nagpe-peel off ung rubber) for some reason.
Kaya shifted to neutons na although mas mahal at 2800 per tire.
Planning to try accelera phi-r since 2500 per tire din siya.
January 21st, 2020 04:33 PM #1942
January 23rd, 2020 02:22 PM #1943
*SE,
Fleet? Haha isa lang car ko, daily driver kaya mabilis din maubos tires. Pero usually I purchase two at a time. Ung fronts lagi bago then ung mas luma sa rear.
May firsthand experience ba dito regarding sa westlake SA57? Maganda sana ung tread pattern nya kaso parang nabasa ko dati na maingay daw itong tire na ito. Can anyone confirm? Thanks.
January 23rd, 2020 03:39 PM #1944
January 23rd, 2020 04:33 PM #1945
January 23rd, 2020 07:25 PM #1946
Hehe daily driver ung sedan. Ung everest and fd, di ako ung gumagamit. Ni-detail ko lang. Hehe
As I've said, ung fd naka champiro gtx pro, noisy as f**k.
- May 2010
- 81
January 23rd, 2020 11:06 PM #1947Hi masters, pls help, need to replace my tires, 5 years na sya thou makapal pa for my cx5, ang size nya 225/55R19 ang hirap hanapin.. any suggestions na sana di masyado mahal po.. salamat
January 23rd, 2020 11:14 PM #1948
Move up 10mm wider... 235/55/19. A bud just got a set of Nexen Nfera RU1 from Big A Autotech(+639150760759). If I recall right, they were sub7k each.
NEXEN TIRE
- Mar 2005
- 703
January 23rd, 2020 11:27 PM #1949The ones I canvased where TireShakk has Toyos OPAs(?) that are that size, not just the same model (Not A36s, oem) at around 10k/pc I think/recall. Drive+ have Hankook's I think at same size. I changed to Achilles Radial Desert Hawk UHP 235/55/R19 from Mindanao Tyre Haus last November at 4k/pc instead of taking TireShakk or Drive+ since they're nice and got good reviews for a hell of a lot cheaper and they fit the OEM rims of the CX-5 AWD. My only regret now is I only bought 2x back then...
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
