Page 212 of 240 FirstFirst ... 112162202208209210211212213214215216222 ... LastLast
Results 2,111 to 2,120 of 2394
    Nov 2016
    #2111
    Usually if it's a brand that makes model specific ones like Eibach it shouldn't have any issues assuming the tire diameter is the same as stock. You could get stiffer shocks and taller bump stops. With these, contact will be minimized and at least it's the bump stops that will take the beating, not the body.
    Thanks. Are these bump stops the same as what people call "rubber lifters?"
    #2112
    Please i need your advise... i just recently discovered this on my tire... will this cause any problem or unsafe issue?
    No need to replace yet?
    4 scratches but not deep...i think ka level lang ng lettering sa tire yung natuklap...TIA!
    mukhang di naman malalim, gamitan mo ng solvent cement (neltex) para di matastas rubber
    #2113
    Quote Originally Posted by neoson9999 View Post
    If by rubber lifters you mean the ones that go in between the spring perch and the spring, no.
    This is an example:
    Some bump stops are located outside the strut assembly.
    But a good set up should still rarely hit the bump stops. Best go with the lowering springs that were designed for your car with the right tire size to match.
    #2114
    So I lowered my car recently. I'm quite happy with everything except for the rubbing that occurs when there is a sudden change in road elevation and or when I turn a bit too fast.
    I'm currently on 195/55/15. My friend suggested that I change to smaller tires to lessen the rubbing.
    Now I'm thinking of downsizing the front tires to 185/45/15. Front tires only since I find no problems with the rear tires at the moment (and budget concerns haha).
    Is this a good idea? Would I encounter problems if I push through with this?
    Edit:
    After doing some searches I don't think 185/45/15 tires exist lol. Maybe I'll go with 195/45/15.
    What do you guys recommend? Thanks
    may i inquire, what is your car, and by how much was it lowered?
    do the tires rub when turning the steering wheel to opposite extremes?
    Kung gasgas lang yan, it will be fine. Pero kung may sugat tapos kita na yung ply, change mo na.
    No ply seen naman... thanks egan bai...
    Will search for it... thanks bruh!
    I will monitor this from time to time to see lang if it will get worse...
    Nov 2016
    #2116
    This is an example:
    I see! Okay I will look into those. Thank you
    It's a 1997 civic. It was lowered by I would say... 2.5 - 3 inches.
    Yes, it does the rubbing sound when i'm making a sharp turn.
    It's been almost a month now I think since I lowered the car. I see no signs of damage on the tires so far so there's that at least.
    #2117
    Wow that is a huge drop. Did you just get lowering springs? Kits are always better as the dampers, bump stops etc are all compatible with the springs.
    #2118
    Kung lowering springs lang on stock shocks, di oobra yun. The worse kung gumamit ng putol springs.
    Best to go with a lowering kit (shocks, springs, etc.) that matches properly to the car. Dami nyan for the Civic EK.
    Apr 2008
    #2119
    Guys, hingi sana ako ng recommendation on tire brand. Need ko magpalit ng 4 tires, ito yung size 205/60/R16, around 4K-5K budget per tire. Ayoko ng made in china na tire. Kung may alam din kayo store na nag-ke-carry ng tire size na yan pa-banggit na rin ng name ng store. Thanks.
    #2120
    Quote Originally Posted by drawdee View Post
    try the yokohama outlet near the dulo of aurora blvd in pasay city, in front of kia, near the end of that road.
    i can't give you the number, but i am confident it is in google. "yokohama tires".
Low budget yet good quality tires
