Results 2,111 to 2,120 of 2394
- Nov 2016
- 29
November 3rd, 2020 10:59 AM #2111
November 3rd, 2020 11:16 AM #2112
November 3rd, 2020 11:31 AM #2113
If by rubber lifters you mean the ones that go in between the spring perch and the spring, no.
This is an example:
Some bump stops are located outside the strut assembly.
But a good set up should still rarely hit the bump stops. Best go with the lowering springs that were designed for your car with the right tire size to match.
- 52,731
- Oct 2012
- 4,851
November 3rd, 2020 12:08 PM #2115
- Nov 2016
- 29
November 3rd, 2020 01:00 PM #2116I see! Okay I will look into those. Thank you
It's a 1997 civic. It was lowered by I would say... 2.5 - 3 inches.
Yes, it does the rubbing sound when i'm making a sharp turn.
It's been almost a month now I think since I lowered the car. I see no signs of damage on the tires so far so there's that at least.
November 3rd, 2020 01:11 PM #2117
November 3rd, 2020 01:23 PM #2118
Kung lowering springs lang on stock shocks, di oobra yun. The worse kung gumamit ng putol springs.
Best to go with a lowering kit (shocks, springs, etc.) that matches properly to the car. Dami nyan for the Civic EK.
- Apr 2008
- 125
January 19th, 2021 02:36 PM #2119Guys, hingi sana ako ng recommendation on tire brand. Need ko magpalit ng 4 tires, ito yung size 205/60/R16, around 4K-5K budget per tire. Ayoko ng made in china na tire. Kung may alam din kayo store na nag-ke-carry ng tire size na yan pa-banggit na rin ng name ng store. Thanks.
- 52,731
Monk-owned R53
