Results 2,101 to 2,110 of 2394
November 2nd, 2020 04:12 PM #2101
Kung scratch, oks lang yan. Kung gush or laceration on the rubber, that you will to assess properly.
- Feb 2014
- 2,531
November 2nd, 2020 04:15 PM #2102so i checked out gogulong... found the tire i wanted on their website. but didn't have production date info
so i contacted them on FB. 2016 production daw
- Oct 2012
- 4,851
November 2nd, 2020 07:20 PM #2103
November 2nd, 2020 07:40 PM #2104
- Nov 2016
- 29
November 3rd, 2020 08:26 AM #2105So I lowered my car recently. I'm quite happy with everything except for the rubbing that occurs when there is a sudden change in road elevation and or when I turn a bit too fast.
I'm currently on 195/55/15. My friend suggested that I change to smaller tires to lessen the rubbing.
Now I'm thinking of downsizing the front tires to 185/45/15. Front tires only since I find no problems with the rear tires at the moment (and budget concerns haha).
Is this a good idea? Would I encounter problems if I push through with this?
Edit:
After doing some searches I don't think 185/45/15 tires exist lol. Maybe I'll go with 195/45/15.
What do you guys recommend? Thanks
November 3rd, 2020 08:42 AM #2106
Keep the tire size the same for both front and rears. I assume FWD yung kotse mo so it helps in rotation. Tama na yung current tire size mo and putting a smaller tire may not be good for the ride. Since you lowered the car, learn to live with it or raise it a bit to put some clearance on your tires.
November 3rd, 2020 08:57 AM #2107
November 3rd, 2020 09:52 AM #2108
- Nov 2016
- 29
November 3rd, 2020 10:45 AM #2109Yes, FWD. It's a 1997 civic. I can live with the occasional rubbing since it does not look like it's damaging anything but if I could fix it with smaller tires, then I'd rather go for it. Tutal medyo palitin na rin yung 2 gulong ko, mas manipis na tires na lang sana ipapalit ko if ever na makakatulong nga sa pag lessen ng rub.
Bought a set of lowering springs to lower the car. It's one of those generic lowering springs.
November 3rd, 2020 10:49 AM #2110
Usually if it's a brand that makes model specific ones like Eibach it shouldn't have any issues assuming the tire diameter is the same as stock. You could get stiffer shocks and taller bump stops. With these, contact will be minimized and at least it's the bump stops that will take the beating, not the body.
Traffic!
