Results 1 to 3 of 3
    hello!
    recently napansin ko na may singaw yung yung left front wheel ko so i had it checked sa vulcanizing shop. may maliit na pako pala, so inayos nila by removing the tires tapos naglagay ng patch sa loob. nung kinabit na ulit sa rim, hindi ko napansin na baligtad pala, yung inner wall nya ngayon e nasa labas na. checking the tires thread wala naman pagkakaiba kung magkapalit yung inner at outer wall. pero kailangan ko bang ipaayos ulit sa kanila para ibalik sa dati yung tires?
    patulong po
    salamat!
    Aug 2004
    Quote Originally Posted by seymorebutts View Post
    hello!
    patulong po
    salamat!
    If the tread is not directional, no problem. If it is, then have it remounted at your soonest convenience... the only problem with having directional tread mounted backwards is that it's not as safe in the rain, though unless your tread looks like this:
    It's not really a problem.
    thank you sir niky.
    hindi naman po directional, pero how about yung "kain" nung gulong, yung sa inner wall side kasi ay medyo mas may wear kesa sa outside wall. since nabaligtad na, hindi na sya magpapantay sa ibang tires. how about yung balancing and alignment, hindi po ba apektado?
baliktad yung pagkaka mount nung tires??
