Results 21 to 30 of 86
- 83
- 115
October 11th, 2002 12:00 PM #228) ah pang sho show mo sa transhow?.... 17" na yan ...then e super lowered mo pasok sa fenders....grabe ganda non dude!!! :wink: :wink: :wink: :wink:
- 83
October 11th, 2002 01:59 PM #23hehehehe! 17's with the right offset should not be a problem since ive been using different rim sizes with the same ride ht. 15's,16's,17's.. hell i even used an 18" adler for a day. dko na kaya! :mrgreen:
- 159
October 11th, 2002 07:52 PM #24I'd go for the 15s with 55series tyres. Sayang 17 for our local roads, papabilog ka lagi ng mags + marami kang mabubuntis na gulong. You just can't avoid to rush sometimes and forget your riding on 17s. Pag naka 15 safe ka.
If you're more concerned that your ride is not looking as lufet as it use to be because there are lots of civics on spoons and local versions of it have become common, go for the latest speedline, mugen + other japanese race mags para lufet ulit. :mrgreen:
Go for magnesium ones para wala kang kapareho, IMHO :lol:
- 159
- 83
October 11th, 2002 08:38 PM #26thankies! everything is noted. :wink: any more suggestions are still welcome para sa future viewers that might experience the same dilema :mrgreen:
- 13
October 12th, 2002 01:13 AM #28before naiisip ko na 15 lang pero 17 din ang bagsak ko, cguro ingat lang sa mga potholes, pero mas ok pa din ang dating ng 17".. maporma talaga.. :D
- 121
October 12th, 2002 03:18 AM #29Originally Posted by mazdamazda
If correctly plus sized, getting bigger wheels will have no effect on mileage and alignment, and your speedometer.
Acceleration times will degrade in proportion to wheel weight, not wheel size. If the 17's are heavier than the 15's, (which may not always be the case), then acceleration will be affected. If the bigger wheels are heavier, unsprung weight is higher, and the car will need greater force to overcome the greater unsprung weight. In the realistic day-to-day driving world, this will mean very little.
Getting bigger wheels (and doing it correctly by plus-sizing) will also net you wider tires, thereby increasing the rubber you place on the road. Handling will get a little bit better, and steering becomes more responsive due to the shorter sidewalls (meaning less sidewall flex!).
I say, if you have the cash, go for 17's. Good for aesthetics, and good for that little bit of improvement in handling.
17s are NOT made for compacts IMHO...
Balance must be achieved, and there does come a point when a car has wheels that are "too-big" for it! 17's (for now) seem to be the most optimum sized wheels for subcompacts and compacts.
- 83
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
