Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 65
    Jun 2010
    #41
    Quote Originally Posted by MrGunn View Post
    Smart Key right?
    Possible na faulty brake light switch. Saw the same problem in another forum, brake light switch ang problem. Attached ang smart key natin sa brakes, so worth it to check this out. Possible din an fuse issue. Check fuse blue 15a, baka loose, this fuse controls the brake light switch. Kung loose push it down lang.
    HTH
    sir kung ito lang ang problema, dapat hindi po pwedeng mag-redondo yung sorento niya. basics of A/T.
    #42
    Anong basics of A/T yan?
    Hirap pag walang first hand experience sa mga engine start button.
    Basta di brake switch, most possible battery yan.
    Apr 2006
    #43
    Battery, no doubt about it. Our Jazz was only a few weeks old when the battery died so the idea is not farfetched
    #44
    Quote Originally Posted by ratchet23 View Post
    oo nga. bukas daw checheck nila dito. sunday kasi wala service e kelangan sana namin gamitin mamaya baka may work-around like yun nga series sa ibang battery kaso wala akong cable pang series..
    - musta na car mo sir? Most common answer by the experts is that battery yan eh.
    Aug 2006
    #45
    Wow this is the first... I hope it's not serious...
    Any update sir?
    Saang Casa mo dinala?
    Aug 2008
    #46
    fuel pump daw yung problem. yung batt e malakas pa daw. pag tanggal sa fuel pump yung socket niya sa negative side parang me namuong corrosion. kulay light brown na yung socket.. hopefully yun nga ang problem. balik sila mamaya together with the replacement parts. sa bahay lang gagawin..
    Sep 2010
    #47
    ^ battery yan kita mo pagbalik nila ng spare parts, di pa din aandar yan. pano nila nalaman malakas ang baterya eh maint free yan. sayang lang pabalik-balik. tingen ko yun unit mo di pa din na-servican ng recall kasi may problema sa wiring sa pinto lights ang Sorento
    and you should wish and hope na battery lang kasi kung yun ang corrosion nakow for a brand new car tsk tsk tsk
    Aug 2008
    #48
    umandar na yung sorento. sa may fuel pump nga problem.
    thank you all for the help..
    Aug 2006
    #49
    Wow good to hear that sir, did they tell you what causes the corrosion? Or isolated ang issue?
    Dec 2007
    #50
    Ratchet, that's really good to hear. Were you able to take some pictures of the problem? What could have been the root cause of the corrosion in the fuel pump connectors or assembly? Hopefully it will not happen again.
    So the diagnosis is " it's the fuel pump". Prognosis is, hopefully "well", enjoy your sorento again.
    Back to discussion of good things about the vehicle.
KIA Sorento R CRDi wont start...
