Results 11 to 18 of 18
February 28th, 2015 12:47 PM #11
+1 here. I never owned a isuzu trooper but what's the viscosity of tranny & engine oil stated in the manual? Im guessing baka same lang naman so no point of discussion here.
when i said tranny oil is a hydraulic fluid I'm referring to tranny oil in general. for instance an ATF is also used as a hydraulic fluid in some power assisted steering systems, in some modern manual gearboxes like Benz, BMW etc... my mistake as I overlooked the subject heading as MT by TS. hehe
+1000 here
+1000 here
- Sep 2008
- 587
February 28th, 2015 12:56 PM #12Kimbon; my trooper which has a 4JG2 engine uses 15W-40 engine oil which I also use for my tranny as specified in the manual
- Sep 2010
- 181
February 28th, 2015 10:16 PM #13yung iba kasi sabi nila feeling daw nila mas maganda yung gear oil at saka daw mas malambot shifting...pero ako since then engine oil na talaga gamit ko 15W40 multigrade...ma 11 years na yung Sportivo ko, 2005 model, ayus pa naman takbo, wala ka maamoy clutch lining, as in very smooth pa tumakbo, yung shift stick ko lang ang medyo malaki na clearance kakakambiyo...kahit nga yung mekaniko ko, nakikipagtalo na gear oil daw dapat ipalagay ko, pero I insist...tas hinahaluan ko na lang ng tranny oil additives na X-1R....
- Apr 2014
- 132
March 1st, 2015 12:14 AM #14Ilang beses ba kayo mag change ng transmission oil mga master? Once a year ba o base din sa mileage?
- Sep 2008
- 587
March 1st, 2015 01:03 AM #15
- Sep 2010
- 181
March 1st, 2015 08:46 AM #16obserbasyon ko, sobra na ang 40K kms, kasi at 39K kms nung mag palit ako, may mga alibaba na dun sa langis na pinalitan...so siguro kelangan medyo agahan, at least pinaka late na yung 35K kms...kasi siguro at the start of 35K kms, nagsimula na ma degrade yung langis....kaya nga yung iba ginagawa lang 20-25K Kms nagpapalit na...lalo pag mumurahin langis lang ginamit tulad sa petron...
- Aug 2014
- 391
March 2nd, 2015 10:29 PM #17hilander lang po yung sakin, pareha ng specs ng engine oil and recommended per manual for the transmission.
March 10th, 2015 07:53 PM #18
Crosswind owner here (xto 2001 model). Yes i still use engine oil for the transmission of my ride, as stated in the user manual. At 290 thousand kilometers, wala pa naman ako problem sa tranny.
Even nga yung filler plug ng transmission ng crosswind, may nakalagay na use engine oil only.
