Results 21 to 30 of 31
- Mar 2009
- 125
September 24th, 2009 09:49 PM #21
September 24th, 2009 10:30 PM #22
BRO, tama ang mga nasabi mo pero kulang lang , kung baga half truth lang ang sinasabi mo, baka nakalimutan mo na ang isang properties ng coolant ay it helps to increase ang boiling point at dahil dito nakakatulong ito na masmaabsorve ng tubig ang heat na pinuproduce ng engine.
September 24th, 2009 11:40 PM #23
- Jul 2008
- 935
September 25th, 2009 01:51 AM #24
September 25th, 2009 01:52 AM #25
bat kasi nawala yung search facility ng forums
anyway...good thing i still found my old posts
http://tsikot.yehey.com/forums/showthread.php?p=83235
http://tsikot.yehey.com/forums/showt...t=24142&page=2
and added info...
http://wiki.answers.com/Q/Is_Distilled_water_corrosive
I once heard in a meeting, sabi nung isang head engineer namin, corrosive daw ang distilled (or was it deionized) water. I found that suprising, but did not question since beterano na yun.
I've made my own brew of engine "coolant" from propylene glycol and some anti-rust additives. These are basically chemicals that prevent the oxidation of iron metal. Add ko lang, yung green or red or pink color ng "coolant" is nothing but a dye to give you a visual indicator na may coolant yung cooling fluid ng radiator mo.
hope this helps.
- Jul 2008
- 935
September 25th, 2009 01:58 AM #26
September 25th, 2009 02:14 AM #27
paki basa nalang po dito, baka makatulong
http://en.wikipedia.org/wiki/Coolant
dagdag ko na rin
http://en.wikipedia.org/wiki/Radiator_(engine_cooling)
September 25th, 2009 03:11 AM #28
Pwede rin sir, 100% distilled water, yun nga lang meron "risk" of corrosion ang radiator & engine.
I said "risk" because there are times during abnormal operations that the water becomes steam and this steam is corrosive.
Ngayon, bakit "distilled" water? Distilled water is 100% water. Meaning there are no impurities, no minerals. There are occurence when water is boiling that calcification is formed. Ito yung mga puti na parang tartar sa loob ng radiator. This formation, pwede magbara sa pipings ng radiator.
Sir, sorry po. Di naman half truth sir. 2/3 truth naman. Nalimutan po. Sorry.
September 25th, 2009 08:59 AM #29
Simple common sense... yun ang recommeded sa manual.
Different brands of coolant may offer different proportions of anti-rust properties and other chemicals. But "anti-rust" is a relative term. The idea is, yung coolant additive na ilalagay dapat chemically neutral sa lahat ng materials na dadaanan nito sa loob ng cooling system (metal, aluminum, copper, rubber, maybe even plastics). The chemical should prevent any corrosion from forming. If it's not chemically balanced, it's possible that the coolant additive itself may cause the corrosion. The Isuzu coolant additive (or any OEM coolant additive for that matter) has been designed to be used specifically on their respective engines. They are "Long life" if you use it on engines it is designed for.
Yung mga aftermarket coolants were made to be used on a broad array of different cars, so the chemicals they used may not be ideal for a specific engine.
Case in point, we had a Lancer GLXi from a decade ago. For at least a couple of years, gamit nun yung OEM na long-life coolant from the factory. On its 40k PMS, we decided to drain/change the coolant to Prestone. 3 weeks or a month later, nagleak yung water pump. Coincidence or not, I'm sticking with OEM coolant additives. It may be more expensive (konit lang naman), but this is something that you do only once in a while naman. And not to mention the peace of mind that you get.
September 25th, 2009 09:25 AM #30
Each ISUZU LLC cost around P350 per liter. One may need around 5 liters for every radiator flushing.
Daming issue ng SU7:grin:
Xiaomi E-Car
