Results 1 to 1 of 1
- Dec 2002
- 2,335
July 3rd, 2004 05:36 PM #1caster: 2 deg 10' +/- 45'
camber: 0 deg +/- 30'
king pin inclination: 12 deg30' +/-30'
toe in mm:0 +/-2
steering gear type: integral, ball screw
gear ratio: 15.8:1
oil pump type: vane
torsion bars
length mm: 1217
dia mm: 27
front shocks: gas filled, double acting, telescopic
piston dia: 30mm
stroke: 130mm
compressed length: 390mm
extended length: 260mm
stabilizer bar dia: 26 mm
rear shocks: "ditto"
piston dia: 25mm
stroke:185
ext.length: 504
comp.length: 319
stabilizer dia: 19mm
wheels:
16x 7JJ
offset: 38mm
16x6JJ
offset: 30mm
PCD wheel studs: 139.7mm
standard tyres:
245/70R16
pressure front: 30psi
rear: 34 psi
Suzuki JIMNY [merged threads]
