Results 1 to 10 of 14
- Nov 2005
- 3
November 3rd, 2005 10:05 AM #1I just got an 1998 Japanese imported Trooper Bighorn.
Some of the power window switch plastic bottons are broken. Can anyone advise a good place to buy such original spareparts?
- Aug 2005
- 10
- Oct 2005
- 33
November 12th, 2005 12:04 AM #4hmm any luck on those switches? i got mine broken too, drivers side pa.. gnawa k, kinalas ko un contacts sa passenger side tapos nilipat sa drivers side. pls advise kng san kau nakakita.. tnx!!!
November 16th, 2005 02:30 PM #5
good luck if you're trying to look for a surplus..hehehe...sobrang hirap yan! my pickup has those same switches and it took me at least half of my day to look for one but was not able to find any...sabi nung mga surplusan sa banawe, hirap daw talaga yan...so your best bet would be a bnew one...yung single switch nya cost around 2k plus ata, so just imagine the price for the main one...are they physically or just mechanically broken? if mechanical lang...magagawa pa yan. -- i had one of mine replaced with an ordinary one, although pasok naman dun sa housing, nakaangat paren kaya mejo panget (sabi kse d na raw maayos). but i tried bringing it to rey's electrical when the other switches gave up, they were able to fix it! so there you go..hehehe...but yeah, most likely walco has 'em.
- Nov 2005
- 3
November 17th, 2005 03:39 PM #6Trup: Thanks for your advise, definitely I will try Walco next time I get to town - note I am located far up north, let you guys know when I have checked this out.
BeetOls: Interesting experience, obvious a common problem. The problem is on the driver / left side. On two of the switches the plastic holding pins are broken and those springs thats suppose to be there are missing. In addition the 'Lock' switch doesn't work cos the spring-pin mecanics are missing the botton cannot click to the lower position.
- Aug 2005
- 10
November 29th, 2005 06:31 PM #7i tried walco last saturday, 4500 yung main switch, 2500 naman yung individual. mahal. i ended up having it fixed dun sa mga nakakalat na electrician dun. pinalitan ng nissan switch yung main ko then did some repairs, 1600 bayad ko sa lahat. ok naman sya, bale yung window lock switch lang ang hindi pareho ang puwesto sa housing kaya binutaqs yung housing ng lock ko
November 30th, 2005 07:57 PM #8
ganyan den nangyari dun sa passenger side ko naman...pero i might go for the orig if the main switch finally breaks down. kse yon ang gamit palagi eh.hehehe...
*barrel -- post ka naman ng pic so if its nicely done naman and hindi malayo dun sa orig, pwede naren! TIA
December 1st, 2005 07:51 AM #9
If you want nice switches. Hans tools in shangrila has em. Pero hindi parin original. And maraming bad experiences dun sa shop na yun. Anyway, just try your luck na rin kung mapadaan ka.
- Nov 2005
- 3
December 10th, 2005 08:12 PM #10Thanks for your help guys. Now I bought the main power window panel (drivers side) from Walco. It is original, fit and works very perfectly.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
