Results 1 to 10 of 21
June 1st, 2004 01:43 PM #1
Bros and sis, meron akong nabasang old thread dito about engine oil of 4jg2 engine Trooper. Maganda raw performance ng 5W-30 engine oil para sa 4jg2. But 5W-30 ang recomended sa 4jx1 at 10w-30 sa 4jg2. Ask ko lang comments nyo about using 5W-30 on a 4jg2 engine? Nakalagay kasi owners manual na "Not recommended for sustained high speed driving" ang 5w-30 sa 4jg2. TNX.
Tsikot Member Rank 3
- Dec 2002
- 636
June 1st, 2004 07:45 PM #2The 5w30 is really spec'd for the 4JX1 engine due to the common rail. The 5w30 mentioned is also a full synth oil, a mineral based one can't be used for high speed driving.
For standard diesel engines, you can use 15w40 like delo gold, mobil delvac.
June 1st, 2004 10:31 PM #3
jackaroo: medyo naguguluhan ako. ibig b sabihin nun di pwede 4jx1 sa "sustained high speed driving"? di b mas powerful nga yan at mas matulin? tnx.
niwde11
June 1st, 2004 11:12 PM #4Originally posted by niwde11
niwde11Signature
- Dec 2002
- 2,335
June 3rd, 2004 01:19 AM #7
hindi ba prone ang trooper na magleak ang oil sa mga seals pag gamit 5w-30 na oil? masyado kasing malabnaw yung oil.
- Dec 2002
- 636
June 3rd, 2004 05:21 AM #8PROMDIBOY
The leaks are possibly caused by old oil seals or gaskets which were removed of built up gunk with the use of a full synth oil. The Petron 5w30 full synth oil should not leak if all seals are still good.
- Dec 2002
- 2,335
June 3rd, 2004 12:05 PM #10yes, 4JG2. delo gamit ko ngayon, 15W-40. Tried din yung Petron Trekker na 10W-30. Balik ako sa Delo coz cheaper and it's the recommended viscosity for our temps
Monk-owned R53
