Results 11 to 19 of 19
- Dec 2002
- 2,335
July 1st, 2004 09:26 PM #11boknoy: I think one has to see the basics of how a turbo works para maliwanagan dito. The turbine is moved by the exhaust gas coming from the engine. This in return is connected to a compressor wheel (more like a centrifugal pump) that "compresses" the air into the cylinder so that more air means more fuel you can inject producing more power. It takes a certain amount of exhaust gas to turn the turbine (because of inertia) kaya may turbo lag. The turbo syst has to overcome this so that the compressor on the other side of the shaft spins faster and compacts just enough air to the cylinder to give you the additional power. Pansin ko lang sa 4JG2 around 2000 rpm yung start ng noticeable boost and around 3200 rpm yung optimum. This is the reason kaya yun ang nasabi ko. Based lang yun sa rig ko. Hope this helps
July 1st, 2004 10:14 PM #12
Tnx sa mga input. Buti na lang nandito si master boknoy and gary.
Sir bok, kailan b matatapos Phd mo sa 4jg2. hehehehe.
July 5th, 2004 10:26 AM #13
Lord Garyq,
I bow down to your humbleness and your wisdom... iba talaga si guru....
Lord Nwdie11
Matatagalan pa.... kasi medyo complicated pa ang 4Jg2 yung sa DMAX nga hilo na ako eh...
- Dec 2002
- 2,335
July 6th, 2004 12:10 PM #14boknoy: loko mo ko ha bro sino ba pwede makausap tungkol sa tranny ng ubs69? Yung sa local GM ba yung tranny or Aisin-Warner? Nga pala ano ang konsumo nung local na 4JG2 na matic tranny? May matic ba na lumabas? Thanks!
- 10,620
July 7th, 2004 08:59 AM #15dude may kilala yung friend ko taga angeles city
magaling sa auto tranny ng bighorn.
- Dec 2002
- 2,335
- 10,620
July 7th, 2004 11:11 AM #17yup sa angeles siya kasi yung kaibigan ko na nag fa-facelift ng bighorn (UBS) to trooper (UBR)
had encountered A/T tranny problems.
nasabi lang niya, nung tine test drive ko ang kanyang (plaisir) model na bighorn.
and yes capampanga ako.
- Dec 2002
- 2,335
July 7th, 2004 01:46 PM #18cabalen ka pala. Taga Magalang dad ko. K pag may time ako bisitahin kita para rin for some parts nang rig ko. Salamat uli!
- 10,620
July 8th, 2004 08:53 AM #19sure pre, text ka lang.
try ko rin kunin ang contact number nung tranny expert.
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
