Results 11 to 12 of 12
- Jan 2009
- 35
November 23rd, 2011 09:34 AM #11Dapat hindi sya bababa. Either magstay sya or tataas lang ng konti. Anyway, try to locate the vacuum hose from alternator to solenoid valve na naka attached sa injection pump. Baka disconnected sya. Pero pagka connected naman pala sya, disconnect it from alternator atska mo higupin. Dapat tataas ng konti ung RPM mo. Dun mo malalaman na baka barado ung hose. Pagka hindi sya tumaas, try to find new hose then attached it to solenoid valve atska mo higupin uli. Pagka hinde parin sya tumaas, wala problema hose mo. Disconnect the hose from solenoid valve and connect it to alternator. After that, switch-on the aircon. Dapat may maramdaman ka sa another end ng hose ng medyo paghigop. Pagka wala, baka sira ung vacuum ng alternator mo. Pagka meron naman, most probably baka may problem solenoid valve mo or ung electrical component na nagco-control sa kanya.
In my case kasi, ganyan din nangyari sa akin. Lalo pa naman automatic ung sasakyan ko. Pagka-on mo ng aircon and pagka shift mo ng D talagang ang lakas ng vibration na parang mamamatayan ako ng engine. Sabi ng isang makaniko baka sira ung vacuum ng alternator ko. Pero nag-second opinion ako and all of this test has been conducted and they finally found out na barado lang pala ung hose ko. Medyo nalagyan sya siguro ng dumi nung huling pinaservisan ko ung alternator. Hindi na ako nagpalit ng hose kasi medyo ok pa naman daw, di naman sya matigas. Instead, they just clean it using compressor. Until now it works very fine.
Hope this will help you. Many thanks. Cheers!
November 24th, 2011 10:53 PM #12
surefire salamat sir! gumana na po pinalinis yung hose tapos okay na
Daming issue ng SU7:grin:
Xiaomi E-Car
