Results 21 to 24 of 24
- Aug 2009
- 420
August 21st, 2010 12:07 AM #21
sir. dati po.. minsan umiilaw po ung brake light after a sudden stop..you should add another force to the brake bago mawala yung brake light sa likod na ilaw.. what is speed sensors, saan yun? syensa na po - km reading po un? when i return to our province i will try your suggestion. palitan ko nalang ng bago fluid - bleeding. baka ito na ang dahilan. so that the signal will not disturb while im driving.
August 21st, 2010 12:43 AM #22
Replacing the old fluid by bleeding all 4 wheels is good. Be sure to remove the fuse for the ABS first. You have four wheel sensors one on each wheel. Linis muna, wheel speed sensors are expensive in fact ABS systems cost a lot especially the pump and modules. Hand brake switch should also be checked as wheel as brake pads/shoe some even have wear sensors which sends info to the ABS system.
- Apr 2009
- 36
August 23rd, 2010 03:26 PM #23i went to rey electricanung fridayl, malapit lang pala sila sa lugar ko in cubao. alternator voltage/voltage regulator ang sira ng sportivo ko, so far so good ok na car ko.
- Aug 2009
- 420
August 23rd, 2010 11:29 PM #24
good evening, sir.
a) Replacing the old fluid by bleeding all 4 wheels is good = can i replace the brake fluid container only? the bleeding part. sir, i dont know if the CASA in our province can handle this.
b) Hand brake switch should also be checked as wheel as brake pads/ some even have wear sensors which sends info to the ABS system = ah ok. i dont think also our ISUZU CASA can handle this also. simple headlight problem sabi nila baka ung BULB ung problema.. the bulb that i used is more than 3 to 4 yrs ko na ginamit. then busted. tapos pinalitan ko same watts, busted ulit. i dont know kung sa bulb
does it mean no huge differences between ceramic vs crystalline ?
