Results 11 to 16 of 16
April 29th, 2009 11:28 AM #11
Have the filter changed, and while the filter is out try and pump some fuel through the pipe to make sure that there is no blockage in the fuel pipe.Maybe the tank itself requires cleaning perhaps a build up of water in the tank from condensation It requires investigation before you go out on the road or your engine might stop altogether, and leave you in a right pickle.
- 84
May 2nd, 2009 12:56 PM #12Hello po mga sir,i have a 96 isuzu pick up with the same problem before,namamatay yung engine during cold start pero pag uminit na, bumabalik na rin sa normal yung idling. Akala ko normal lang yung ganun since diesel naman sya at malamig pa. Pero minsan nag leak yung injection pump ko and no solution but dismantle the IP and at the same time i-calibrate na rin para isang gastos na lang and voila! balik sa normal yung idling. Hindi na namamatay yung makina during cold start. Baka po kailangan lang na ipa-calibrate na. Sana po makatulong.
May 3rd, 2009 07:24 AM #13
updates lang....
i had the nozzles cleaned -- that did the trick, barado pala.
Now while i'm at it, i decided to have the engine rebuilt; it's currently in the works, will replace just the piston rings, intake/exhaust valves, valve guides, main and con rods, pati naren pressure plate and clutch disc! whew!
medyo nagbabawas naren kase ng langis although di naman malala pero medyo mausok na...at para wala naren problema hopefully for another year...
nakakabutas ng bulsa..hehe...decided to go OEM all the way para less headache pagkatapos.
Thanks for the inputs sirs!
- Apr 2009
- 36
June 27th, 2009 09:39 PM #15
- Sep 2008
- 630
June 29th, 2009 10:24 AM #16Baka sa injection pump yun, ung amin po kasi ganyan din problem pero nung dinala sa san pedro laguna i forgot the name of the shop, pero expert sila sa isuzu magaling ang mga gumagawa nag training pa sa japan mga mekaniko kaya ayun pag tapos palitan injection pump ok na ulit.
Ilan na po ba milage nung sasakyan nyo?ung sa amin kasi 240k+ na nung pinalitan IPV 2001 model
Ayos sumabay pa sa Greenbelt 1.
Makati CBD parking
