Results 11 to 18 of 18
- Mar 2010
- 6
March 23rd, 2010 11:00 AM #11
[SIZE=4]guys.. may problem ... regarding sa clear heads.. knowing na salamin sya, dinala ko sa asahi at pina--- refurnish? refurbish? kung ano man ung term na un... is panget ang kinalabasan... ill be posting pictures... later.. another problem pa po ay... ung metal reflector sa loob ng head light... unlike sa mga modelo ngaun.. ung makikintab ung reflector nila at may design to focus it on the road(kasi pag clear makikita nyo ung loob is may silver coating tpos reflector pa..... ung s trooper kc.. ung pag kaka frosted ng glass headlights nya is may factor sa focus sa karsada...nakita nyo naba ang loob ng heads ng trooper nyo pag tinangal ung salamin?? i did... and medyo disapointing.. ung pictures later na lng..medyo busybusyhan lng.... and di ko sya sa asahi dinala... dahil massive production pala sila dun.. di pede tingi.. hahaaha! [/SIZE]
[SIZE=4][/SIZE]
[SIZE=4]-ibigay mo na... ibigay mo na.. ang iyong tilapiang........ SAKSAKAN NG TABA!!!!!![/SIZE]
March 23rd, 2010 12:39 PM #12
That's sad to hear. It may have been better if you just had your headlamps cleaned. With the pics you posted with the HIDs, it may have improved after the clean.
Just the same, we'd be interested to see photos of how your "hoped-to-be-refurbed" headlamps turned out.
- Mar 2010
- 6
March 23rd, 2010 01:27 PM #13
i had my heads cleaned up... in addition... its a bit difficult to remove the glass covers of the heads especially the sealed type versions... knowing its bit fragile cause its glass even if its thick.... i am satisfied with the output of the HID with frosted heads.. its clear namn... and it is still projecting great focus and quality of "beam" the only difference that i noticed between frosted and clear heads is the shape of the beam.... you can see talga ung 2 cones of beams when you are using clear heads and a bigger cone (some say its "sabog/kalat")on frosted.... "take note... in my observation lng ha.. baka mali din ako.. hehe" mag popost po ako... pag uwi na pag uwi ko sa manila...
April 6th, 2010 04:52 PM #15
Bro its better to do retrofit the headlight with projector light kung clear lens na yung headlight ng trooper mo. Hinihintay ko lang spare kong headlight from US. Garyq will do it for me to do it clear and retrofit with projector light. I will post here after our project is done.
April 6th, 2010 05:33 PM #16
I have made a similar post in another thread here. These are Bighorn options in Japan. This would be a better alternative than risk your OEM headlamps. As you may know, headlights are factory sealed (lens) and may result to moisture.
April 6th, 2010 06:18 PM #17
benzmizer; me isang forumer dito na nakaganyan although custom made yung kanya. nakita na rin nap123 minsang me isuzu EB kami 2006 pa yata kasama si 4jgtootsie, djerms, etc. forgot his hadle here though. try ko dig yung mga pictures sa laptop ko.
April 6th, 2010 10:23 PM #18
bro nakita ko na yan. Yung project namin ni gary actually kayang kaya niyang gawan ng clear lens ang headlight ng trooper as in as OEM ang labas. He knows already what is good iretrofit niya ng projector as OEM medyo high end at pricey lang pero sulit. I have already bought a pair headlight sa US paship na hinihintay ko nalang. this is a good project and I want this to have it. Eto pala ang ikakabit niya sa headlight ng trooper http://store.theretrofitsource.com/p...7051f1915f8a03
once naclear lens na niya.
Monk-owned R53
