Results 1 to 5 of 5
- 12
March 27th, 2008 07:48 AM #1Hi I just had my tanny repaired because it was leaking oil however my mechanic asked me if I could find out the specs for the oil to be used in my tranny, transfer case and rotary? does any on know the specs, brand and viscosity? thanks very much appreciated.
James
March 27th, 2008 09:58 AM #2
i pressume local 4jg2 engine mo. same as your engine oil, 15W-40. ayan nakalagay sa manual. hth.
- 12
- 12
March 27th, 2008 10:10 AM #4k thanks is it the same for the transfer case and diferential? and is it a fully synthetic oil?
March 27th, 2008 10:18 AM #5
yep same for the transfercase but different for the differential. afaik, all 99 truper differentials are LSD so you need GL-5 oil for your differentials. btw. engine oil 15w-40 it is not fully synthetic.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
