Results 11 to 20 of 51
April 9th, 2007 04:35 PM #11
Yes sir may 4jx1 expert dito dati Paul Chua ang pangalan niya kaso ibang solution ang ginawa niya.
Habang hindi pa naghahalo ang langis at diesel ninyo, I suggest pa hugot niyo na ang injectors to replace o ring ninyo para iwas overhaul.Last edited by 4JGtootsie; April 9th, 2007 at 04:39 PM.
April 9th, 2007 04:42 PM #12
- Nov 2006
- 15
April 9th, 2007 04:43 PM #13loko talaga itong mga taga Isuzu, they also advised me pala na palitan ko raw yung rear pressure sensor i dont if rail pressure sensor or rail sensor yun raw yung sira na nagpapahina ng acceleration ng trooper, but I didnt believe them, do they have a point?
April 9th, 2007 04:57 PM #14
April 9th, 2007 04:57 PM #15
yan din yung hirit nila sa akin, but for sure kahit palitan mo yan, d ka pa din satisfied and then eventually, sasabihin nila ay sira na yung injectors mo. gasgas na yang linya ng isuzu. had 3 of my friends fed the same lines.
- Nov 2006
- 15
April 9th, 2007 05:12 PM #16all I tot maganda talaga ang Trooper because of its 160hp but meron palang badside, kaya pala hindi ko mahabul habul ang fortuner na 2.5 G nung nag landtrip kame, meron pala talagang sira ang engine ko.
April 9th, 2007 05:17 PM #17
the sensor is cheaper para ipagawa mo na, then after a while the injectors na. true reality yan, kaya kaw magdecide if you still want to keep the trooper. if not sell mo na, kasi pag bumigay na yan, no choice ka na kungdi ipagawa at gamitin since napalitan mo na yung mga mamahalin na parts.
- Nov 2006
- 15
- Feb 2007
- 27
- Nov 2006
- 15
April 10th, 2007 04:13 PM #20Sir Kcboy I met just this AM a friend of mine and asked him the performnace of his trooper, he told me that its running good and havent change any injectors or any other parts the only thing that he keeps on changing is the oil filter, the air filter, the engine oil, and fuel filter, his mileage was already at 110,114, I was amazed by what I heard about his car, he only does is a every 4000km checkup.
Suzuki JIMNY [merged threads]
