Results 1 to 10 of 32
November 15th, 2005 04:33 PM #1
Downgrade ako ng ride, gusto ko isuzu pa rin. OK kaya LS pick up. Budget ko sana is mga 250k. What are the problematic things to look out for ?tnx
November 15th, 2005 10:26 PM #2
Hi, I own an Isuzu LS. Ok Siya. Tipid talaga tsaka super tibay. Revery reilable. Things you need to check though when buying 2nd hand are the ball joints, steering damper, tie-rod and ends. Also check the engine for any signs of loose compression.
November 16th, 2005 02:18 PM #3
yup..i own one too...got the 4x4...basically, same engines naman ang mga yan with the fuegos eh (4ja1 and 4jb1t)...mine's cbu from japan, pangalawang LS namin ito, we had the 4x2 previously but sold it...iba talaga pag cbu (from my experience)...never needed suspension parts replace until its 9th year (or 190,000 kms)...everyday used ito...now it already has 197k kms on it. and its still doing fine...just don't expect too much power from it...hehe. parang ang bibigat ng kaha ng mga yan compared to fuegos...d na ba pwede i stretch for a 2nd hand fuego...you can already get 1 with 300k +
November 17th, 2005 09:31 AM #4
workhorse pala talaga ito. Pareho din ba ang hatak ng crosswind and this pick up? I really wanted a fuego kaya lang medyo tight talaga budget. Yung 300th na sinasabi nyo sir, mga anong year kaya yan lumabas? Puede din siguro ipon muna ako. Bihira din kasi ang nagbebenta ng fuego and pick up.
November 17th, 2005 07:03 PM #5
try to check the "for sale" section of 4x4ph..hehe..saw one there...makinis pa with some upgrades. kaya lang 350k ang asking eh...4x2 lang pero 4x4 look...2002 and up na fuego 4x2 na yon...try mo nalang to look around in ortigas...dami dun, autocamp, goldpark, and yung sa tabi ng adb and poveda...
we currently have the 4x2...1996 model den pero single cab long bed sha for company use, hell yeah it will definitely smoke the crosswind, kahit xuvi or xtrm pa. pero shempre, sobrang gaan na kse non. generally same lang dapt kse same engine sila...everything will come down to whichever is lighter.
November 23rd, 2005 01:17 AM #7
Hi, I saw a 1998 LS for sale in Buy and Sell. It's only 270K. Search http://www.buyandsellph.com. Keyword "LS" without the quotes. You can also search Fuego.
January 23rd, 2006 01:13 PM #8
I already saw one pick-up, 1997 model. When i drove it, i noticed na yung temp reading nya( hindi pala dial type ang thermometer nya) ay below the 1/2 mark. Normal ba yun? At tsaka yung ISUZU badge nya sa likod ay maliit na nasa top left portion. Nagtataka lang kasi ako dahil most that i've seen ay malaking ISUZU na nasa middle nakalagay. Sabi nung owner, 2.4 diesel daw makina pero i notice na pareho ito nang sa crosswind na 2.5.
January 23rd, 2006 02:32 PM #9
Ang alam ko the temp should be in the middle or 1/2 line below the middle. Eto ang normal operating temp ng LS. Dial type. Kapag way below sa 1/2, malamang sira ang thermostat.
Tapos ang engine ng LS is 4JA1 na 2.5liters (actually it's 2.499.) Ang badge niya dapat ay isang malaki sa center ng Tailgate. Malamang yang badge sa tailgate ng seller ay nabili niya then kinabit na lang. Kasi ang ganyang badge (small-top-right) ay inilabas Fuego 2002 and above if I'm not mistaken. YOu can buy that from Walco or from any Isuzu casa. Kung ako sa iyo, I will look for another pickup. Marami sa http://www.buyandsellph.com.
January 23rd, 2006 02:39 PM #10
actually ang thermostat nya ay hindi dial type but rather vertical(yung parang station selector indicator ng mga transistorized radio). Halos na-inspect ko na mga pickup sa buy and sell and i would say almost all of them are in a bad shape.
Monk-owned R53
