Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    I see some trucks do that. Wouldnt it make it more unstable and prone to tip-over since the design was for 6-wheels?
    Apr 2004
    It does if you mount the rear wheel like you would the ineer wheel.. if you mount it the way the outer wheel is mounted it becomes almost as stable as a 6w provided it is not loaded to its maximum payload capacity. 4W and 6W trucks vary only a few inches in dimensions and commonly with the same engine. Payload capacity is the main advantage of a 6W truck.
Isuzu Elf from 6 to 4 tires
