Results 3,681 to 3,690 of 3710
October 18th, 2019 12:53 PM #3681
There's no doubt about it. Just exercise patience in your hunt.
Masarap maghanap lalo na kung ready ang budget for it.
Also, bring a very good mechanic - na kikilatis mabuti.
I have a friend who brings his trusty mechanic every time he decides to buy a 2nd-hand vehicle.
Naalala ko kuwento nya: Bilin lagi nya sa mechanic nya is kilatisin mabuti at "pintasan lahat ng puwede nyang maipintas." This way, it gives my friend a good idea on what needs to be done pa sa vehicle and knowing such, how to haggle the last price for the vehicle.
Naalala ko yung mga hunt namin ni Mrs ko dati whenever we buy second-hand vehicles.
Suwerte naman at laging maayos ang nakukuha namin (papers and all). Siguro kasi, at the first instance of "duda" or "something is not right," we politely back away kahit gaano kaganda ang itsura ang labas ng sasakyan.
I also remember, once nakakuha na kami, we change all the fluids (brake, coolant, power-steering fluids).
And lahat ng sinabi (kung meroon man) ng mechanic ay ipapaayos namin. We also change all the tires to brand new (if the case warrants it). Then, go to a detailing shop. Kapag luma na tint or 4 years running na yung tint, we also change them to new ones. Then, pa-bless namin sa Antipolo and Manaoag, Pangasinan.
Good luck!
AK
- Jul 2015
- 7
October 22nd, 2019 04:07 PM #3682
- May 2016
- 546
October 23rd, 2019 01:22 AM #3683Not necessary. Some users swear it smoothens out engine vibrations.
Here's a study I found with a quick google search. Take note the study was conducted in South Africa.
2-Stroke Oil In Diesel – A Technical Study
Conclusion:
2-stroke oil can contain around 16ppm zinc, or higher depending on the formulation and batch.
Trace amounts of zinc in diesel are known to rapidly accelerate injector nozzle deposits.
Engine test results show that a 200:1 blend of 2-stroke oil in diesel results in a 2% loss of engine power in a 16 hour test due to injector fouling, a risk that would apply to any common rail diesel engine, but could also worsen fouling in older engines.
Vehicles fitted with a diesel particulate filter (DPF) in the exhaust system could experience reduced DPF life due to the collection of ash and metal based contaminants in the filter over time with the continued use of 2-stroke oil.
- Jun 2011
- 1,077
November 12th, 2019 01:52 PM #3684https://www.autoindustriya.com/truck...-php-962k.html
"Powering the Traviz is a 2.5-liter 4JA1 BluePower direct-injection diesel. If the name sounds familiar, it is because the engine was derived from the Crosswind AUV. It puts out 78 PS at 3900 rpm, along with 176.5 Nm of torque at 1800 rpm, and is Euro 4 compliant."
Kaya naman pala gawing Euro-4. Puwede pang buhayin ang Crosswind.
Maganda ma-update sa ABS at Airbags.
- Apr 2008
- 6,237
November 12th, 2019 02:59 PM #3685Ganda sana if they gave it more power while they were at it. But as it is I see droves of jeepney operators getting this. Probably the only old school diesel in the market rated Euro 4. Fuel consumption matching modern CRDis with old school diesel maintenance cost! May nanalo na!
Sent from my SM-G965N using Tapatalk
- Jul 2009
- 5
November 23rd, 2019 08:54 PM #3686hello po. NagpaPMS ako ng Sportivo 2010 namin kanina (plus change oil and ATF dialysis). Per checking nila sa ilalim, ang daming need palitan 😭
Center Post 3k
Ball joints 5k
tie rod 2k
idler 3.5k
Transmission Oil seal 4.5k
wheel bearing 3k
labor 3.5k
Makatarungan po ba ang prices? Also, yung ball joints, idler arm, tie rods and center link were also replaced dec 2016. So normal lang po ba na for 3yrs, papalitan sila ulit (Im driving daily house to school ng mga kids po then mga once a yr na long drive, if this will help 😅).
Also, do you regularly do ATF dialysis? Every when?
- Nov 2009
- 3,484
November 28th, 2019 08:04 PM #3687
- Jan 2018
- 42
January 31st, 2020 12:53 PM #3688Hi! Ask ko lang if kaya bang ipush start yun crosswind na MT? 3 years na yun battery eh and na discharge ata for not using for 5 days. Ayaw mag start kasi kanina so nag commute nlng ako.
January 31st, 2020 01:25 PM #3689
January 31st, 2020 06:14 PM #3690
