Results 1,151 to 1,160 of 1770
- Jan 2010
- 12
January 12th, 2010 07:53 PM #1151thank you po, nakita ko na yung problem, binaklas ko lahat and nilinis ko yung loob ng switch, ok na sya di na nag stuck up hopefully yun lang ang problema. Salamat po sa mga tips nyo
talaga pong nakatulong ng malaki!!!
January 13th, 2010 04:11 PM #1152
Mukhang ok na yung Crosswind ko. Before kasi ang topspeed ko is 80kph pero noong nag adjust ako ng driving style pumalo na ng 100kph. Kaya pa siguro above 100kph pero hindi ko pa na try. Medyo nasanay na rin ako sa slow acceleration niya. I own a 2002 XUVi A/T. Nabili ko ito last December 21, 2009. Mga 2 weeks pa lang sa akin. Siguro noong una nag aadjust pa ako.
January 13th, 2010 07:31 PM #1153
January 16th, 2010 12:03 PM #1154
I was able to try the italian tune up just last weekend at NLEX, going to bataan.. Upon entering NLEX i felt medyo sakal ang takbo ng crosswind ko so what I did was to stop at the first Petron station going north then had my Air Filter cleaned, after that ramdam ko na ung hatak sandali ko lang nareach ang 145.. saka di masyadong maingay ang makina unlike ung ibang takbo ko.. I think kailangan ko na magpalit din ng Air Filter..
Can anyone recommend a good Air Filter for Crosswind?
January 16th, 2010 02:01 PM #1155
January 17th, 2010 01:21 AM #1156
try niyo ung mga aftermarket...
btw kanina may nakita ako sa nlex sportivo naipit sa van at bus.. halos madurog ung sportivo
- Feb 2007
- 12
- Jan 2008
- 38
January 23rd, 2010 03:48 PM #1159hello to all,
just have a question regarding tire pressure ( psi ) for crosswind XL which rides on 185/80 R14 tires... the recommend tire pressure chart located at the side on the driver's door indicates the following psi:
front tires - 27psi
rear tires - 47psi
is this supposed to be followed exactly?
or should we follow the recommended tire psi from the tire manufacturer?
(which i still do not have accurate data from yokohama )
it seems that the 27psi in front might be too soft while the 47psi at the rear is a little too hard.
i've heard other people putting a uniform 36psi in all 4 tires in XL's while others put 32psi in all 4 tires of sportivos ( which rides on 235's )
any input will be greatly appreciated. many thanks.
- Jan 2008
- 38
January 23rd, 2010 04:20 PM #1160btw sirs,
i believe our unit came out of the dealer without any undercoating provided. they did not include this since they gave add'l discount.
any advice regarding undercoating & rustproofing for crosswind?
Ok ba sa ziebart? i think it'll cost around 10k for what they call complete rustproofing package.
kung undercoat lang... around 3.5k
ilang taon na battery?
What is the Longest Life of your Car Battery?
