Results 1,671 to 1,680 of 1770
August 9th, 2010 12:26 AM #1671
August 9th, 2010 01:17 AM #1672
August 9th, 2010 09:51 AM #1673
Thanks sa mga replies nyo..sana nga ganun lang problem nya. San ba magandang reputable mekaniko pwede ko to ipacheck? alam nyo po ba number ng Jaysons or Walco auto supply? kasi just in case may bibilhin akong pyesa dun ko na lang kukunin. Thanks
- Jan 2008
- 38
August 9th, 2010 01:47 PM #1674hello to all,
Question regarding use of AC...
Have you experienced stale-smelling air or "kulong na amoy" coming out of the aircon when only the blower/fan is turned on?
This happens everytime i start the crosswind our for a drive.
The smell disappears once i switch on the thermostat.
The vent is shut so there's no outside air coming in.
I got the unit this January 2010 & i've only logged 3800kms on the odometer.
I've already sent this to ISUZU manila for a check-up since it's still under warranty.
They couldn't give me a straight answer as to the cause.
They've cleaned the AC but the problem is still there.
Anyone share the same scenario? Comments, opinions, advice?
TIA
August 9th, 2010 07:21 PM #1675
napa check ko na XUV ko, it turned out na ito nga naging problema nya. sumasabit yong stopper nya sa turnilyo na suppose to be na bumabanga sakanya..so pano sir tholitz, ibig sabihin ba nito everytime now and then maglalagay ka ng grease dun sa stopper? ano ba ibang pwedeng remedyo dito? ang nasa isip ko, kung palitan ko kaya ng malaking ulo yung turnilyo para babanga talaga sya dun sa stopper. If so, ano naman kayang size ng turnilyo pwede dito? pls help for some inputs..thanks.
August 9th, 2010 09:58 PM #1676
August 10th, 2010 04:08 PM #1677
- Feb 2008
- 2
August 10th, 2010 06:53 PM #1678hi all. recently purchased from a friend who left a 2005 crosswind XL. sobrang good deal, i couldn't resist but buy it.. my inquiries po;
- running now at 130km, ano dapat maintenance check gawin ko?
- water separator is lit up, how do i drain po yung separator?
- rear door left side behind driver seat, pumasok yung tubig sa loob ng door mismo, ayaw tumagas, weird parang nag iipon ng tubig sa loob if it rains.. ano po dapat gawin ko?
thanks a lot ahead sa replies.
Tsikot Member Rank 3
- Mar 2003
- 637
August 10th, 2010 08:57 PM #1679ok ba yung 2010 crosswind XT variant mas ok ba ito kesa adventure gls sport and innova j?
August 10th, 2010 09:22 PM #1680
Do PMS intended for 120k. That should mean drain all fluids (brake, oil, coolant, transmission/gear). Have the fan belts checked and underchassis.
As for the water separator, pump the water out. The separator is located near the firewall (near the HVAC).
For the water in the door, the door drain may be blocked/clogged. Have it checked and get that water out of the door to avoid corrosion.
Personally, yes. But the answer to your question may vary depending on who you ask. Best that you check the 3 brands/models and compare based on your need and expectations.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
