Results 1,251 to 1,260 of 1770
March 8th, 2010 10:35 AM #1251
- Feb 2010
- 194
March 8th, 2010 11:38 AM #1252Thanks sir. . . So there's nothing to worry for me. . .how about the excess ATF, sobra kasi sya sa dip stick measure. . .even more than "H" level. . .di ba supposedly, if its "C" or cold, lower, then pag "H", higher na. . .sobra pa sya sa H. . . How about also sir the watery ATF in my transmission. . . 0k lang ba yon?
Thanks again. . .
- May 2009
- 119
March 8th, 2010 11:49 AM #1253sir rsnald thanks for the reply...fyi hindi ko pa binili yung pump sa casa...watch mode muna kasi tumigil na yung leak sa ilalim ng pump...kaya check na lang palagi level ng coolant sa radiator at sa reservior..before mangyari ito nag pinuno ko hanggang max line sa reservior ng coolant with engine cold then duon ako nakaexperience ng konting leak sa ilalim ng water pump ng leak ciguro mga 10mm from the max line ng reservior ang nabawas...but when I check it when the engine ran for about an hour upon checking nasa above max line yung coolant sa reservior...hmmm..it makes me wonder may pressure relief valve kaya yung pump kasi kapag cold at nasa max yung level ng coolant and when the coolant goes hot it will expand then above max line na..kaya what I did hindi ko na dinagdagan yung coolant to reach the max line below ako ng mga 10mm when cold..pero when I check when nakatakbo na yung engine nasa max line na yung coolant level...kaya sir watch mode muna...kapag natuluyan yung pump ko I'll take your advise na hi-lander pump na lang gamitin ko...
- May 2009
- 119
March 8th, 2010 11:58 AM #1254
- May 2009
- 119
March 8th, 2010 12:36 PM #1255today just sent my crosswind for emission test kasi due for registration ako this month..last night nilinis ko muna yung tail pipe by using water hose inserted to the exhaust pipe and rev the engine to around 4K rpm for several times...ang daming lumabas na carbon deposits....then the result ng emission test for CO2 is 0.29 maximum allowable is 2.5 nakalimutan ko yung unit ppm yata...6 times pala kukuha ng reading kaya 6 times irev yung engine...then the CEC is valid for 2 months pala kaya what I did is pinaxerox ko incase na may humuli sa akin na sabihin na belching black smoke yung ride ko pwede ko ishow na pasado ako sa recent emission test ko...
March 9th, 2010 12:30 AM #1256
MUsta mga sir. newly owner of Crosswind here, just got our 2010 XUV (last friday lng). tanong ko lng xempre sa tire pressure(gasgas na gasgas na itong tanong na to :P ) based on your experience ano tire pressure yung pinaka magbibigay ng comfortable ride?(15 inches ata rims ng XUV) pansin ko lng din, medyo mausok na din ung XUV nmin miski bago pa, pero di naman sobrang mausok ah, kc ini expect ko dahil bago ung car eh medyo clear smoke pa ang lalabas...(or dahil diesel xa kaya ganun tlga)
ask din tungkol sa diesel consumption, pano i compute to ng tama and anong range ng speed ng car para makuha ung pinaka accurate consumption? na try nmin kc pumunta kmi ng batangas eh ayun sa computation nmin eh 11.09 km/l(pinaka max speed nmin eh 120kmh)
at share naman kayo ng mga tips para lagi nasa good condition mga Crosswinds ntin. SALAMAT!
March 9th, 2010 11:18 AM #1257
Alangya nanakawan nanaman ako ng sidemirror(3rd time), may nagpost dito sa isuzu ng protector ng side mirror, di ko na mahanap. San page ulit yun mga bossing?
Warning sa inyo dont leave your crosswinds sa Morato, Quezon ave unguarded parking spaces. [SIZE="5"]*******NG MGA MAGNANAKAW YAN!!![/SIZE]
Sorry just venting
March 9th, 2010 09:57 PM #1259
- Nov 2008
- 125
March 10th, 2010 08:01 AM #1260Gusto ko palitan ung headlight ko hehe para magmukhang Sportivo 2010 Model haha. how much kaya yun. and how much pala magpa chrome kasi di ko na madaan sa linis yung chrome don sa may gulong(yung natatangal).
Traffic!
