Page 87 of 177 FirstFirst ... 377783848586878889909197137 ... LastLast
Results 861 to 870 of 1770
    Feb 2005
    #861
    I am having problems posting at the Classified Section of Tsikot so would just like to briefly jack the thread with a unit my friend is selling:
    2009 Crosswind XTi M/T
    11,xxx kms.
    Mercury Silver (like Diamond Blue)
    Car Plan (spoiled unit)
    Ending "6" (Wednesday coding)
    Added Accessories:
    Stepboard
    Doorvisors
    Two-eye Backup Sensors
    Foglamps (OEM Crosswind Sportivo specs)
    Back up Light (OEM Trooper foglamp specs)
    Roof Rack
    Rear Spoiler with Third Brake Light (OEM Sportivo/XUV 2009 Specs)
    Fender Mirror (Genuine Accessory for Crosswind)
    RFS: Migrating to Canada
    750k (negotiable upon viewing) --- Price of XTi at time of purchase: 915k
    0918 9082690
    . Look for Pol
    #862
    Nice unit, I like the fender mirror.
    I also like this one, Fender Side Mirror from Carryboy, but I haven't seen any Crosswind having this fender mirror.
    This cost Php2,300 including installation from carryboy banawe. So what do you think? will this look good on a sporty Crosswind variant like an XUV or Sportivo?
    Again one Bob
    Sep 2009
    #863
    *Benz and Gerbo
    Thanks po sa info. Another followup question po if ok lang.
    With regard sa Ac I think it just has a dirty evaporator. since ung pressure ng freon is still at 40-PSI kung my butas un dapat depleted na ung freon.
    Ung sa evaporator sa harapan medyo madali baklasin. but ung sa Likod medyo palaisipan.. ung evaporator sa likod. there are 2 tubes. one has a connector one doesnt. kelangan ba putilin ung isa , tas lagyan na lang connector pag balik?
    We fix AC ksi but ung pambahay lang. so kami na lang din ang nagseservice ng ac ng mga sasakyan namin. the thing is di ko lang alam kung paano ung assembly ng rear eveporator ng crosswind. pag putol ko baka my bigla pala na connector sa ibang parts durog diba. hehehe
    ung sa peanut lights naman po, paano po ba babaklasin ung dashboard para macheckup ung lights. then ung sa AC switch po paano po palitan din ung lighs noon. meron po ba kaya na website na my walkthrough with regard to dismanlting the assembly?
    then ung sa Headlight din dati ung left side un ung ok ung brightness ilaw then ung sa right mahina. (ung parang umiilaw but power is mahina. ngaun naman nagpalit naman. ung sa right naman ung malakas and ung sa right naman ung humina. i have checked the fuses mukang ok naman po.
    And Sir benz ayos tong post na crosswind nyo po. asteeg ung porma.
    Feb 2005
    #864
    Quote Originally Posted by TholitzReloaded View Post
    Again one Bob
    It looks good too... my only reservation is why does it look like it's installed on the LH side of the fender? Being a LHD vehicle, it's should be on the RH side of the fender.
    Other than that, it is a nice functional accessory to install on a sporty Crosswind (XUV/Sportivo) --- sporty din naman yung design nung fender mirror
    [SIZE="2"][QUOTE=butirog;1314852][/SIZE]
    Sana pare. That would not entail much cost from your end if cleaning lang kailangan.
    IMHO, i would still suggest for you not to take the risk of DIY the cleaning when you have doubts doing it. Bring it to a DENSO Service Center for cleaning. Then what you could do, you could watch them on how they do it so next time, ikaw na lang gagawa (DIY).
    Yung sa peanut lights naman po, paano po ba babaklasin ung dashboard para macheckup ung lights. then ung sa AC switch po paano po palitan din ung lighs noon. meron po ba kaya na website na my walkthrough with regard to dismanlting the assembly?
    I have seen a dashboard of a Crosswind dismantled before but I don't have proof to document it. hehehe! No site to share too. But as I remember it, you need to remove the dashboard face first. Having removed that, you would have access to remove the instrument panel and the switches.
    Then ung sa Headlight din dati ung left side un ung ok ung brightness ilaw then ung sa right mahina. (ung parang umiilaw but power is mahina. ngaun naman nagpalit naman. ung sa right naman ung malakas and ung sa right naman ung humina. i have checked the fuses mukang ok naman po.
    Since it's working, it's not the fuse. I fear it might be grounded or may need to replace a relay -- for I (and maybe you) is not sure if the previous owner did some "magic" with it's electricals. This is electrical stuff. If you're not adept to it, best to let an experienced electrician take a look at it. Definitely, that's not normal.
    Thanks partner. My friend and I sure hope it goes to good home.
    #865
    Quote Originally Posted by Benzmizer View Post
    It's just a picture I got from the internet but a friend of mine installed exactly this fender mirror (RH btw) on his Pajero, I was about to have it installed also but when I learned that they have to drill two holes in my right side panel I hesitated.. pero now I want to have it installed too for safety reasons, dinikitan kasi ako ng Cher na bus when I went to Alabang last Saturday, buti just a minor scratch on the fender. Helpful kung meron ako nito. I'll post pics as soon as makapagpainstall ko nito to share it with everyone.
    Syangapla nakakita rin nito sa Alterra.. looks good din..
    Sep 2009
    #866
    Nakaka inlove talaga ang crosswind. :D Sirs, ask ko na rin pala, normal lang ba yung may usok pag umaga? medyo grayish yung color ng smoke eh. Pero kapag nakaka 5kms na takbo na, wala na yung usok. Normal po ba yun? 2005 model po na crosswind XT yung sa akin (actually, sa parents ko yun, hiniram ko lang) 58,000kms na po yung odometer reading nya. Nung nag change oil ako last week, dun ko lang napansin na sobra yung usok. Prior to change oil, ang alam ko meron din pero mahina lang at kulay black talaga. Ngayon gray color na at medyo matagal bago mawala. (Shell Helix diesel super 15w40 po yung oil ko. dati daw ninto castrox gtx diesel daw)
    Apr 2009
    #867
    hi .. saan meron Denso? pasig or mandaluyong area meron ba?
    how much cleaning for crosswind?
    yung sa usok sa akin ganun din sa morning.. mdyo maitim pag tumakbo na or mainit na engine its less na and parang mas maputi na usok.
    Feb 2005
    #868
    Quote Originally Posted by anthon05 View Post
    Check this listing out. There is one in Pasig.
    Call them so tehy could give you an estimate on how much it would take to have your Crosswind's aircon system cleaned.
    Apr 2009
    #869
    hi thank you... i did call the one in pasig. Cleaning is 2800
    Feb 2005
    #870
Isuzu Crosswind Owners Thread [ARCHIVED]
