Results 841 to 850 of 1770
September 2nd, 2009 04:26 PM #841
As you mentioned, Suburbia does not extend warranty so drop it in the list. As for Ziebart.... hmmm, drilling holes? Well, these holes will be covered with rustproofing anyway so seems ok lang. Basta walang secondary damage sa oto when they drill, ok lang. Petron, is cheap pero unless you have seen their work, I have reservations din.
September 2nd, 2009 05:32 PM #842
Yun din ung worries ko if ever they drill some holes sa underchassis baka mamaya magkaron ng problem, I've read some threads here regarding the problem they've experienced after a rustproofing job wherein they drill holes. I have yet to check how they do it. I might drop by in Ziebart near Magallanes sometime next week just to check how they do the underchassis coating.
- Sep 2009
- 29
September 2nd, 2009 06:15 PM #843sirs, tulong naman po. ilan po ba talaga ang kailangan ko ilagay na motor oil sa crosswind xt 2005 model (4ja1 type)? Sabi kasi ng ate ko, 5.5L daw. sabi naman dito 4.5L lang. ano po ba talaga?
September 2nd, 2009 06:23 PM #844
Just recently, nagpa-change oil ako crosswind, Shell Diesel Plus ung kulay blue, semi synthetic, bale 4.5 liters yun if I remember it correctly isang malaking container which I believe contains 4 liters saka ung isang small na 1liter ang laman, half lang nun ang nilagay..
I'm pretty sure your suking gasoline station knows how much engine oil dapat ilagay sa crosswind mo.
- Sep 2009
- 29
September 2nd, 2009 07:30 PM #845Thank you po sa reply. isang tanong na lang. magkano po magpa change oil kung shell diesel plus?
September 2nd, 2009 07:37 PM #846
Yung Shell Diesel Plus 4liters will cost you around Php1,100, di ko na matandaan kung magkano ung 1liter siguro mga around Php250 rin yun, yung labor naman is around Php200-250 lang sa shell kung saan ako nagpaservice.
Be sure to bring your own Oil Filter and Fuel Filter, okay daw na brand ang VIC mga more or less Php 200 lng isa nun.
umabot din sakin ng almost Php2k all in all.
- Aug 2009
- 349
September 2nd, 2009 09:20 PM #847
September 3rd, 2009 12:40 AM #848
September 3rd, 2009 07:54 PM #849
Sir,
Thanks for the time. I'm also doing some search but from what I've learned from you, I 'll be more careful in searching.
Joey roo
- Sep 2005
- 2
September 4th, 2009 04:41 PM #850hello!
i acquired a 2001 XTO from my father last January. Alagang alaga nya ito and maganda ang takbo. Matipid din sya, nakaka 12KPL ako, city/slex driving.
may isa lang akong napansin,
since january, 3 times na nababali yun tubo ko sa main muffler. Yung first time, ang cause daw eh nasira na yun rubber (shaped like an 8) thingie that holds the muffler in place. pero yun last 2, buo pa yun rubber pero bali ulit yun tube connecting directly to the main body of the muffler.
ang sabi ng tatay ko, never daw nasira sa kanya ito, so malamang daw dahil sa driving ko kaya nasisira. di naman ako balasubas pero di rin ako mala-pagong magmaneho.
meron din ba kayong similar problem with your xwind? I will have it checked again tomorrow, probably papa-weld ko na naman pero I want it to last a bit kasi hassle din yun palaging nasisira.
Thank you!
