Results 751 to 760 of 1770
- Sep 2008
- 45
August 13th, 2009 01:20 PM #752Konti pa lang gumagamit ng synthetic oil pra sa 4JA1 engine. Isa na ko dyan. Why not try? pra makita mo rin yun effect.
From my experience, mas okay ang synthetic oil. Mahal kumpara sa mineral oil. P500 per gallon but its worth to try.
- Aug 2009
- 149
August 13th, 2009 03:09 PM #753^^so how often you change oil? every 5k pa din or 10k na using synthetic oil?
August 13th, 2009 04:12 PM #754
yeah how many kms before you're next change oil? and how many liters or gallons do you put in a 4JA1 Engine, do you need to put other additives?
August 13th, 2009 05:10 PM #755
Your brake rotors needs to be refaced, 250-350 per side dati sa mga machine shop (except labor ng mechanic mo) . Both front should be done at the same time, also change your brake pads as they are already uneven in wear. Buy good quality ones... Though they are not really that dangerous pero you never know d b?
August 13th, 2009 05:15 PM #757
Sa oil I use Castrol CRB (pag tipid) GTX pag me pera hehehe... Dont like Petron Trekker maitim ang usok!
- Jun 2008
- 33
August 13th, 2009 06:33 PM #758guys sa 2010 x-wind lineup, yung xti parin ba ang pinaka bang-for-the-buck?
August 13th, 2009 07:08 PM #759
- Sep 2008
- 45
August 14th, 2009 11:51 AM #760After the first change to synthentic oil, you need to change on 5km then the succeeding on 10km. Btw, before you put synthetic oil, you need to put a flush to existing mineral oil (I forgot the brand). Rev your engine for 20mins then drain. This will help to remove remaining residue. I bought synthentic oil from SpeedyFix. Sila lang alam kung meron ganitong engine oil.
4 gallons of Royal Purple synthentic oil for our 4JA1 engine. No additives needed. Don't forget to apply the prescribed oil Viscosity of your car.
You don't have to change every 5km but on every 10km. Better lubrication. From my experience, I noticed the improved engine performance (Dati hirap sa rangkado). Smoother shift of gear (dati hirap ako mag shift galing sa 1st to 2nd gear).
Please check this site for advantages of using synthetic oil: http://www.autotropolis.com/wiki/index.php?title=Synthetic_vs._Mineral_Oils
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
