Results 641 to 650 of 1770
- Oct 2007
- 6
April 1st, 2009 03:35 PM #641
April 1st, 2009 03:41 PM #642
- Oct 2007
- 6
April 1st, 2009 03:42 PM #643
- Feb 2009
- 6
April 4th, 2009 02:14 PM #644mga ka isuzu fan,
ano ba ibig sabihin ng EB? palagi kc yan ma mention sa thread till now hindi ko pa alam ang meaning nyan...
April 5th, 2009 03:56 PM #645
- Oct 2006
- 4
April 6th, 2009 11:55 AM #646[quote=rsnald;1218407]on the shocks, stick with OEM, KYB gas type. I dunno kung may advantage using other types pero matched yung KYB sa suspesion system ng crosswind sa harap at likod. la nang isa-swabe ang crosswind, talgang matagtag.
on the side mirror: depende kung anong type, pero baka malaglag kayo sa upuan pag nalaman nyo kung gano kamahal. yung di power, if I remember correctly, nasa 8 thou yata per piece (casa price ng Isuzu pasig), yung power window, 13 thou yata. That was 3 years ago or so.
__________________________________________________ __________________
thank you very much for the info. May alam ka ba pwede makunan ng murang shocks? I inquired at rapide and it would cost about 3250 per piece.
di ko lng natanong baka kasi kasama na labor dun. Medyo mahal pa rin.
- Feb 2009
- 6
April 6th, 2009 03:44 PM #647
April 19th, 2009 12:58 PM #648
any auto shop should carry KYB shocks. sabihin mo lang yung pang hilander pwede na din yun. better kung makakalas mo yung nakakabit na orig and bring it to the auto supplies shop together with the rubber bushing. maliit kasi yung rubber bushing that comes with the KYB shocks that's normally available as auto shops. They will have to find an equivalent big rubber bushing.
mga 1000+ lang yata per piece yun.
ON FAN BELTS
advise ko lang fellow crosswinders on fan belts maintenance, do not, I REPEAT, DO NOT USE THOSE "belt dressing" sprays for the fan belt.
These are those can spray treatment supposed to be for your fan belt pag dumudulas na yun fan belt mo and it will make the belt "stick" again to the alternator, power steering and flywheel (tama ba?) pulleys. What those sprays contain are actually solvents that soften the rubber material of the fan belts hence making it stick to the pulley. It will shorten the life of your fan belt and at worse, it will cause the fan belt to break prematurely!
this obviously happened to me. after a few uses of the said fan belt treatment, nagkaron ng punit yung fan belt ko, and my mistake was I didnt immediately replace it coz i was on the road. ayun, inabutan ako while driving buti na lang i was still not speeding up. The first sign that made me aware that the fan belt was broken was that the steering became very stiff.
luckily i was able to maneuring my car to the side where I replaced the fan belt using the old fan belt that i always carried w/ me sa car.
Also, when the fan belt breaks, for some reason, the battery gets discharged, even if you ran for just a short distance. So kelangan mo magpa push start. so, the moment na dumudulas na fan belts nyo, either tighten it by adjusting the power steering pulley, or have it replaced na the soonest.
hts ;)
may ilang tips pa ko ibibigay regarding :
1. leaf spring replacement
2. cleaning of the fuel water separator
and other stuff that i'll have to recall (senior moment na eh ehehehe)
find time lang for me to get the pictures i took
good day to all
- Apr 2009
- 544
April 20th, 2009 12:50 PM #649hi fellow isuzu owners..
im driving an xto. recently i just replaced my clutch master assembly.
bought a Seiken mahal kasi OEM. and two kinds pala yun may steel and aluminum, opted for the steel kasi mas mura sya and sabi ng mechanic matibay ang steel.
my question is ano diffirence ng steel and aluminum? pls share your experience.
bili ko sa steel is 1800 while the aluminum is 2500.
and another question , aircon ko kung sobrang init panahon parang kulang na sa lamig, sabi sa akin lagyan ko daw auxillary fan, is this true?
and baka mabilis masira battery ko?
thanks i hope you can share your insights on this.
April 23rd, 2009 06:24 PM #650
sirs,
Lately napapansin ko medyo bumigat steering ng hilander XTRM, though di naman nagbabawas ng power strng fluid, saan kaya problem? mukhang ok din naman mga belts. Also thinking of changing the 15" OEM rims of my XTRM, though nag iisip pa ako ano babagay, same size din para no need to change tires PCD 100 ba yun o 114? Thanks in advance!
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
