Results 1 to 10 of 28
- Sep 2010
- 28
November 14th, 2010 10:18 PM #1Mga sir, newbie here needing your help. We recently acquired Crosswind '04 (3rd owner na kami) and we later found out na nabangga pla ng previous owner. Sabi sa casa faulty na yung steering gear box causing excessive play. halos gumegewang na kami sa NLEX at 80kph. i Had the tie rod ends replaced, checked the centerlink, ok pa naman cya.
Wheels already balanced and aligned, Stablizer bar bushing checked. Coupler also in good condition. So, gear box na lang ang possible culprit.
Ask ko lang po, will i Change the gearbox or have it repaired? Meron po ba overhauling ng power assisted gear box? Please help. Medyo madugo po ung b-new steering gear box from ISUZU Center. I read sa ibang thread na kaya i-repair ang gear box. Thanks po!
November 14th, 2010 11:35 PM #2
The usual protocol is to have it repaired/adjusted first. You would only need a repair kit to do this. It is only after the steering box is opened you would know if more repairs (replacement) is required.
What did the CASA recommend pala? If they said repair using repair kit, pwede.
- Sep 2010
- 28
November 15th, 2010 02:08 PM #3Thank you sir Benz! Had it checked today, sabi ng mekanik okey naman yung gear box. What we noticed pag iniikot yung manibela half turn left-right, gumagalaw taas-baba yung body. baka daw loose balljoint kaya off-camber ang wheel. Hopefully mkita na talaga ang problema. Fortunately, hindi po gearbox like ISUZU said. Their assessor came with that conclusion within minutes w/out even looking under the chasis.
November 15th, 2010 07:33 PM #4
- Sep 2010
- 28
November 16th, 2010 12:31 AM #5Yes sir! If by chance I accepted their assessment and had the gear box replaced, di rin maso-solve ang problem. Lalaki lang ng lalaki ang gastos till they overhauled the whole front end. 75thou pa naman sa knila ang gear box,35 thou for the power steering pump assembly. WALCO is offering 45thou for b-new gearbox, 22thou for the pump.
- Sep 2010
- 28
November 16th, 2010 08:40 PM #6Ok na po Sir Benz, wala na free play yung steering. It cost me less than 3thou. Thanks po!
November 17th, 2010 12:53 AM #7
- Feb 2004
- 138
January 6th, 2011 06:29 AM #8
January 7th, 2011 12:13 AM #9
January 9th, 2011 02:02 AM #10
sa mga gurus natin dito, paano po ba i-flush and fill and power steering fluid ng ating mga xwind?
And every ilang thousand kilometers dapat gawin to?
thanks for the help
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
