Results 1 to 10 of 14
June 3rd, 2004 02:12 PM #1
hello again guys, i have another question for you SUV experts out there.
i noticed that my brakes begin to get a little stiff after driving for some time, usually during long drives (e.g. manila - bataan). they start off feeling normal when i begin my drive but tend to get stiff after an hour or so (almost an hour sometimes) of driving. can anyone help me out here?
its a 95 isuzu bighorn LS, no ABS but with 4-wheel discs. i have bigger sized tires (i forgot the actual size), the ones that the 2003 and up skyroof edition trooper use.
Tsikot Member Rank 3
- Dec 2002
- 636
June 3rd, 2004 04:21 PM #2Pls clarify, do you mean they don't bite as well or it's harder to depress brake pedal?
Have you changed pads, brake fluid, rotors recently?
June 3rd, 2004 04:38 PM #3
sorry, i mean its harder to press the brake pedal thats all. it still stops normally and i dont feel that its harder to stop the vehicle, its just harder to depress the pedal.
June 3rd, 2004 04:39 PM #4
i havent changed anything regarding the braking system since i got the trooper.
- Dec 2002
- 636
June 3rd, 2004 04:52 PM #5Suggest you change brake fluid, new dot3, and check the brake pads and rotors for wear.
If it doesn't improve then you may have to buy a brake master kit- which may be due considering it's 9 years old.
June 3rd, 2004 05:59 PM #6
hmm, that's probably it. same thing happens to our honda civic. probably have to check that too.
- Dec 2002
- 2,335
June 3rd, 2004 09:43 PM #7attic: palagay ko nangangalay ka lang o pagod ka na kaya mahirap tapakan. Yung suggestion ni jackaroo sundin mo ha.
- Dec 2002
- 2,335
June 4th, 2004 08:34 AM #9attic: sa akin due na for replacement yung lining/pads. Sa brake syst pina-drain ko before yung fluid and bleeding. DOT3 at least recommended sa atin
June 4th, 2004 09:18 AM #10
IMO,
as additional sa mga post ni LORD JACKAROO baka kailangan mo din i drain kasi feeling ko may Hangin na ang Brake system.. i try mo muna i bleed
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
