Results 41 to 50 of 67
September 9th, 2009 09:45 AM #41
can't relate to this discussion as my XTO is a manual one but i think practice practice lang because getting used to your car is the most important. knowing it's capacity on certain speed can make you feel confident and safe in overtaking.
September 9th, 2009 11:14 AM #43
i had my XUV since 2003 AT rin... para sa mabilisang overtake
PUMP the PEDAL unti you reach atleast 4.5K RPM then try to stay there!
at higit sa lahat,
[SIZE=6]P R A Y H A R D[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]angel of God my guardian dear....[/SIZE]
September 9th, 2009 11:30 AM #44
Have a boost controller installed, and alcohol injection.
According to DevilDoc, they were able to get a turbo Crosswind's 0-100 km/h times down to 16 seconds (that's nearly twice as fast as stock) with injection.
I didn't see such a big change... but it's possible my XTO has a boost leak, a slipping AT or a worn turbo (130,000-150,000 kms or so...)... still tinkering with it. But I did gain some horsepower with the mod.
Just bummed because I got only 5 hp or so, and other guys with old-school 2.5 turbos are getting 10-20...
September 9th, 2009 10:46 PM #45
September 10th, 2009 04:32 AM #46
Kung papalitan lang din ung transmission i think ang ipapalit ko na is ung manual transmission. I was told pwede daw yon. It its cheaper pa din daw. and I personally thing that is DO-able
But then again di na sya bagay sa forum/topic na to. hehe
If that's possible, do anyone has and idea kung magkano kaya ang Manual transmission assembly for crosswind?
September 10th, 2009 02:30 PM #47
Sa likod. Pero I'm thinking it might be easier to reinstall it in the front passenger footwell, para madaling abutin.
I really think we need boost control... or something... my XTO just doesn't have enough boost to utilize the benefits of alcohol injection. I'd love to tinker with it and see how much more power I can get out of it, but I'm too busy, at the moment with other things.
September 12th, 2009 01:55 PM #48
September 22nd, 2009 07:19 PM #49
It was not really 16 second but a little slower like 16.8
Had to manually activate since the switch was a 6psi switch.
From the guy we tested the kit with and won it as well
Nice meeting you all guys!
Again thank you dvldoc for the prices, especially I won the kit, what else I can ask more ... can't wait to get this installed in my ride. Felt the rush when it was tested on my Crosswind XUVi today (3/22/2008). The Crosswind XUVI A/T with 4JA1-L engine performance is not one of those fast ride known to tsikoteers, but with the Water/Alcohol Injection tested today (I believe used with 35/65 mix), jeeez can't believed it just pulls harder, and harder and faster.
The improvement is very much noticeable at the top end... with the system turned off the acceleration at 60kph going above is slow, but with the system turned on, the performance from 60kph and beyond is a lot quicker. The gain in speed is gradual, but definitely its noticeable. Imagine that 5 sec drop at 0-40mph as logged by dvldoc's accelerometer.Last edited by dvldoc; September 22nd, 2009 at 07:22 PM.
September 22nd, 2009 07:58 PM #50
buti nalang M/t ung akin.. 0-100kph kaya within 12secs. or less.. 3-4k rpm.. 100kph on 3rd gear..
