Results 11 to 18 of 18
October 28th, 2009 10:43 AM #11
sir benzmizer thanks alot! i'll try to follow the manual, very helpful indeed!
sir btw, what is the ideal wattage if i should replace the bulbs?
sorry i have no idea and i prefer sana the "stock" wattage lang para iwas complications. and aside from osram are there any other brands that you can suggest and that can bring out enough light without harming the casings or electricals? and hehe price din sana.
thanks!
October 30th, 2009 03:48 PM #12
October 30th, 2009 05:51 PM #13
The standard (stock) bulb wattage of a Crosswind is 55/60. Either of Philips, OSRAM brands are reliable.
One alternative you could do so you need not have to worry of damaging your wiring harness is to use CERAMIC BULB SOCKETS. I think it's around 1,200-1,500. That includes 2 ceramic sockets, wiring harness and relays. You can then use 90/100 bulbs after installing this without worries.
Philips or OSRAM brand comes into mind. Any auto supply has these. These are normally the brands manufacturers use as OEM bulbs.
October 31st, 2009 04:27 PM #15
If you want Osram Bulb Silverstar or Nightbreaker call Warren Motor Sales in Benavides, Sta Cruz Tel NO.244-17-76 ,244-17-77.
October 31st, 2009 05:39 PM #16
na aim ko na ng sa gusto ko yung headlight ng hilander namin
3 days ang inabot ko bago ko naperfect yung aim na gusto ko hehehe
- May 2008
- 117
October 31st, 2009 06:17 PM #17how do you change the orientation of the headlights for a right hand drive vehicle to one that was converted to left hand drive. read some where that shims are added or that the headlight bracket is replaced to achieve the correct position.
Traffic!
