Results 1 to 8 of 8
- Sep 2010
- 181
January 27th, 2011 04:01 PM #1mga bros,I need help and adivise on how to change my coolant for my crosswind/sportivo,I lost my manual already...how many liters capacity of coolant/water for our sportivo?is 1 liter of coolant and the rest is distilled water enough?how many liters exactly of coolant?pls help bros...TIA...
January 27th, 2011 04:30 PM #2
Unplug your radiator and let the old coolant out. 1.) Either you find a way to collect the outcoming fluids or 2.) you can fill your radiator liter by liter (using plain water) to determine its actual capacity.
If you do #2, you have to let water out again and fill with actual coolant.
As for the coolant, you can the premixed coolant. No need to measure anything. Just pour.
January 27th, 2011 05:31 PM #3
meron din bolt para matangal ang tubig sa engine block para lahat , malinis
- Sep 2010
- 181
January 27th, 2011 06:28 PM #4thanks bro number001,ganun na lang gagawin ko,since hindi ko alam yung exact capacity..sahurin ko ng timba yung old coolant/water....para malaman ko kung gaano kadami yung coolant na ilalagay ko...wala kasi mabilhan ng pre mixed dito sa amin...
bro raine,saan po ba banda yung drain bolt sa block?
- May 2009
- 119
January 28th, 2011 10:53 AM #5sir around 6 liters to 6.5 liters ang capacity ng coolant ng crosswind kung hindi premix dapat 50/50 water and coolant dati yung binili ko in 3 liters na lalagyan tapos halo ng 3 liters na wilkins distilled sakto na siya....magkulang ka lang ng konti dun sa coolant reservior kaya bili ka na lang ng maliit yung nasa 500ml tapos halo ulit ng 500ml may sosobra pa yun pwede mo sir pangtop-up kung nagbabawas...nung nagcoolant ako hindi na nagbabawas ang coolant ko...kaya oks talaga gumamit ng coolant...wag ka na bibili nung may anti-freeze hindi na natin need yun sa may winter lang yun...btw bago ka magsalin ng bagong coolant you can flush it prestone meron din nun lalalabas mga corrosion....
- Aug 2009
- 349
January 28th, 2011 11:40 PM #6ask kulang sir... May bad effect ba ang coolant kapag sobra ang lagay example (30 water/70 coolant) ? ....................TY
- Sep 2010
- 181
January 29th, 2011 12:18 PM #7thanks bro jaz014...napalitan ko na coolant/water ng radiator ko...gumamit din ako ng pang flush na nabibili sa mga auto shop,may mga lumabas ngang dumi,pero kunti lang naman...ginamit kong coolant ay yung nabibili sa petron na coolant,ok kaya yun?tapos yung distlled water na ginamit ko ay absolute,medyo mura ng konti...
- May 2009
- 119
January 31st, 2011 11:36 AM #8sir according sa label sa back ng prestone coolant....adding more coolant will increase also yung boiling point ng mixture...as far as I remember kapag 50/50 nasa 110 degree C ang magiging boiling point then the more coolant versus water tumataas let say around increment of 5 to 10 degrees....
What vehicle and what's your budget?
