Results 151 to 160 of 192
August 10th, 2005 08:16 PM #151
Originally Posted by rsnald
August 10th, 2005 10:24 PM #152
Thanks, sir JeepCruizer. Susubukan kong makapunta ng Evangelista para makapagpakabit nyang flexible tube.
August 11th, 2005 08:56 AM #153
pag sinabing guru....panigurado si rsnald and x-wind yan hehehe
master ng mga crosswindhehe
tnx master check ko mamaya wag sana sa tranny... pwede na ako sa maluwag na bolt hehehe
xwind yung Motolite Excel Tropicalized same parin ng old orig natin yung white? tried and tested na kasi gusto ko ulit ma achieve yung 3yrs hehe
rsnald...sabagay i think i need to change it na...kasi pag sinasagad ko yung power windows to check kung sarado mga windows...pag gabi with headlights on...bigla humihina yung light hehehe :-)
no problem psalm
i think mga 800-1200petot ata yung flexi tube....sa surplus shops ko lang binili to....mas mahal siguro brand new kung mayroonLast edited by Jeepcruizerph; August 11th, 2005 at 08:59 AM.
- 227
August 12th, 2005 12:52 PM #154ehem! nag react na po yung GURU!
ser Jeep, yun bang radiator mo meron na ding 'flexible hose'?
August 12th, 2005 01:11 PM #155
August 12th, 2005 01:57 PM #156
Originally Posted by x-wind
para walang away, si x-wind lang ang guru...ako gurang (utan).
x-wind, pareho pala tayo ng battery ngayon. dalwang version yan, yung isa merong parang viewing hole ng electrolyte level. sana wag yun ang nakuha mo. nag le-leak yung electrolyte sa katagalan (after about 6 months). yung sakin, sinoli ko after 6 months and insisted that they should replace it. thankfully they did.
on another topic: x-wind, advice sa kin nung marunong sa a/c, pa pressure test daw muna yung a/c compressor, meaning disconnect the compressor from the system. tapos kabit ng pressure gauge sa compressor. dapat daw maka build up sya ng 400 - 450 psi. pag mababa ang pressure, loose compression na daw compressor, pa overhaul na or palitan na. kung ok pa ang compressor, palit daw ng expansion valve and dryer. then vacuum system para tanggal old freon, before re-charging with fresh freon + lube oil.
sinubok ko test tingin yung cool air outlet ng a/c ng honda, kaya nya palimigin to -0.5°C yung palabas na hangin. todo ang thermostat nun. yung sakin, hanggang 11°C lang. so meron nga talga depekto somewhere.
hth ;)
August 14th, 2005 11:37 AM #157
cj ano ng yari sa radiator mo naayos ba ni mang mhon and how much yun charge?
August 14th, 2005 01:32 PM #158
Originally Posted by cj
x-wind wat happen to your Ac?...buti nalang pala napalinis ko last march yung A/c ko...grabe ka dumi...may gagamba na ata doon sa comperssor
August 14th, 2005 06:25 PM #159
Mga bosing, tuwing kelan ba ang palinis ng AC? O pag dina lumalamig sa desired or usual temp na ginagamit.
August 15th, 2005 05:00 PM #160
Mga Sir,
Newbie here. I was interested sa thread na ito since my dad bought a second hand 2002 XL 2.5L variant the basic version. it was lady driven and acquired it w/ 18,000 km on the odo back in June 2004. In the times that i was there and was riding it my only comment on the x-wind was the slow acceleration pero iba na ang usapan pag recta. we did not experience the radiator problem up to now same w/ the exhaust. the chassis is holding well and the power is superb.
i learned a lot re the x-wind thru this thread i hope x-wind owners will air any experiences they had or are having.
Isuzu pasig service center is ok yun nga lang grabe sa pricing.
Any comments in using the coco bio-diesel sobra na mahal ng diesel. when i left manila (nov 2004) Php 21.00 pa lang now php 31.00 na ata!
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
