Results 31 to 37 of 37
September 21st, 2009 07:44 PM #31
September 21st, 2009 07:54 PM #32
Indeed, Isuzu could have just copy one of its own and sell it here as a new generation vehicle.
Naunahan pa.
September 21st, 2009 10:10 PM #33
Well... look at it this way.
A Chery QQ costs 400k pesos. Airbags, semi-automatic transmission... all in.
A Hyundai i10 (same size and spec) costs 500k.
Now... look at the difference in quality in the interiors. Which one creaks and rattles, even when brand new? Which one bottoms out over bumps? Which one has poorer panel fit and finish?
It's definitely not the i10...
If you want to sell cheap, you cut corners. Even with Ssangyong, which uses decent MB-based engines and underchassis components, you can see visible cost-cutting in the interior materials of their cheaper cars, the Actyon and Stavic... the Kyron and Rexton, at least, are a bit more upmarket.
With the Chinese, cost-savings are done everywhere. In the trim... in the way the panels are assembled... in the paint... in the choice of plastics used... in the quality of the shock absorbers (which usually go bad early) and the type of steel used in the coil springs and leaf springs.
These things are relatively minor... but the big ticket problems are in the chassis design... which directly affects safety (although the Crosswind has virtually no crashworthiness, either) and the engine assembly... which is the most important maintenance item on the vehicle, as engine replacements can cost up to 200-300k pesos if they fail.
With the Crosswind, it's disappointing that Isuzu has not seen fit to put any money into developing the chassis or improving the build quality of the vehicle. The doors still come out of alignment after a while, due to the soft metal used... the crash-structure is pathetic, and the interior is given to rattles and squeaks, even after just a few thousand kilometers. And the active safety is atrocious... poor handling and woeful brakes mean that you're never going to miss the ability to go 160 km/h, because you'll have a hard time braking from just 100.
But at least the engine is durable, reliable and economical. Thus, I still recommend the base level Crosswind for anyone who needs a work service. The top-of-the-line Sportivo? Too much money for nothing but a tarted-up Crosswind with a video system. You could simply buy a lower level XTi, install leather and Dynamat insulation, and buy an even better video and sound system for less money.
- May 2008
- 161
September 23rd, 2009 10:40 PM #34ang mahal pa rin nito samantalang chinese brand lang ito at siguro hindi ganun ka tibay yan!!hindi pala siguro sigurado pala!!!!!
kaya lang mahal isuzu ksi matibay talaga at proven reliability na.eh ang mga chinese cars sa porma lang maganda
September 23rd, 2009 10:59 PM #35
The Hover will be launched in Australia as X240 with a Mitsubishi 4G62. 2.4L engine.
Here, I believe it will be "assembled" by resurgent Francisco Motors with a 2.8 L diesel engine.
Yeah..there will be many doubters. But it seems Great Wall is one of the best Chinese car companies.
http://great-wall-review.blogspot.co...all-hover.html
As to the Crosswind, it will probably last 4 lifetimes...the engine that is...everything else is doubtful.
September 23rd, 2009 11:00 PM #36
double post! arrghhh.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
