Results 11 to 13 of 13
October 26th, 2010 12:37 PM #11
Slightly OT lang.
When you replace your tires, make sure that they are upto the recommended specifications of the Crosswind. Baka kasi mamaya ma-sway kayo sa pang-passenger car (more often than not has better tire design). Load Index should be top consideration.
October 26th, 2010 10:17 PM #12
Try mo rin sa Goodyear Servitek along araneta ave. Eto breakdown.
Replace RHS Upper Suspension Bushing - 450
Wheel Alignment - 320
Camber Adjustment - 400
2pcs Shim - 90
Sub Total 1260
Machine Shop Press In/Out 500
Php1700
Then before mag 1month binalik ko ulit for inspection may 1month warranty kasi and sinabihan din ako na magkakaron ng adjustment dun sa upper suspension bushing.
Ung upper suspension bushing pala 450 lang bili ko sa Jayson's.
- Nov 2008
- 125
November 4th, 2010 01:45 PM #13may kabig yung sportivo ko paleft pero kunting kunti lang unlike after ng wheel alignment ko sa motech. obvious na may kabig talaga.
Ok kaya sa servitek marcos hi way. para ma-try ko naman service nila.
