Results 1 to 8 of 8
- May 2008
- 117
February 10th, 2009 03:06 PM #1hoping someone can point me in the right direction. trying to find a bighorn specialist or at least knowledgeable with 4wds in the katipunan area. i know there is one for rovers and another for bmws in teachers village,q.c. but i am not sure if i can go there.
- May 2008
- 117
February 12th, 2009 05:53 PM #3would like someone familiar with the vacuum actuator on the front axle and the sotf system. afraid mine is suspect and i am not sure if its functional at all.
February 14th, 2009 09:52 AM #4
TOD ba model mo?
Check first the piping of the vacuum. Marami ng na leche leche na ganyan dahil sa engiune at under washing. Simple lang operation ni yan, solenoid na always shut until activated, reservoiur at switch.
- May 2008
- 117
February 14th, 2009 10:33 PM #5first thing i did. hoses on the vsv looks good. the wiring is also intact. another forum suggested that it might be the sensor on the tcase. pulled out the diagram from itocuk and had used that as a reference. any ideas on how to test it?
February 16th, 2009 10:38 AM #6
Give us a history on how the problem started?
Usually simple on off lang yan engagement is via vacuum.
Pag TOD (torque on demand) baka mas complicated.
- May 2008
- 117
February 16th, 2009 10:18 PM #7it is not a TOD, no button on the dash. the tcase lever has 4H and 4L on it. i had replaced the small thimble like screen filter on the injector pump inlet. had dropped the small retaining bolt, like that is unheard off, and tried flushing it out with a stream of water. never recovered the small bolt and i guess it is still stuck there somewhere if it had not fallen out already. after that, the 4wd indicator started to blink. it still blinks specially when i am going up an incline, like the mall parking building ramps, but stays lit steadily on even tarmac. had checked from underneath but i have not seen any indication of a short or loose wires. cannot even tell if the event with the small bolt was merely coincidental. although the front wheels spin freely in 2H, i still want the problem corrected.
- Jan 2006
- 12
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
