Results 461 to 470 of 822
- Feb 2010
- 8
February 9th, 2010 12:55 AM #461Good day, Can anyone help me. Im buying a Isuzu Bighorn preferably 1997 up model the one with curves dashboard. I have ready budget for a worthy bighorn.
February 9th, 2010 10:32 AM #462
February 9th, 2010 10:37 AM #463
- Feb 2010
- 8
February 25th, 2010 08:51 PM #464Im so thankful that i found this website, it is very helpful to me and im sure for others also...
2 weeks ago, i went to manila from Leyte to find a trooper/bighorn and after few days of searching, i finally found my Bighorn 4jg2 matic. When i bought it, im aware that it has a few oil spill underneath the oil pan, then i decided to go to shell service bay to lift the car and check for that particular oil spill. Hindi nman tumatagas talaga pero nag drop talaga nang few, when i found out that it is just the hose of the turbo connecting to the crancase that is leaking, then we replace the hose tapos na wala na yung tagas. While im driving on my way to Leyte Land trip around 1,500++kms, the diesel is very economical when after few days after I arrived here, biglang maasksaya na sa diesel, then i found out that their is leak again in the hose na newly replaced in mnla. Im afraid baka nasira na turbo ko. Now, my car only top speed of 100kmh at nahirapan pa yun, diesel consumption is terrible. Pls. pls. I need help of the gurus here in tsikot specially to sir 4jgtotsie that im sure can advise me of what to do.
February 25th, 2010 11:19 PM #465
- Feb 2010
- 8
February 26th, 2010 12:33 PM #466thank you sir, but its the oil hose of the turbo charger to crankcase ang nag leleak, does it affect of running performance of my car, coz it has a lot of pressure in it ryt?. My car only run 100kmh top speed and the diesel consumption is multiplied by 2. Pls pls.
- Feb 2010
- 8
February 26th, 2010 12:40 PM #467thank you sir, but its the oil hose from turbo charger to crankcase that is leaking, napaka sikip kc nang makina baka di gaano na tighten yung clamp, yan ang duda ko kc nakaka disturb talaga, my car only top speed of 100kmh and the diesel consumption is doubled. Pls. pls. any other views.
February 26th, 2010 02:53 PM #468
February 27th, 2010 08:03 PM #469
Try to tighten it first. Double banjo bolt yata yan na may cooper washer yan that serves as sealer. Its a tight space. Silipin mo from the right side wheel well tanggalin mo yung rubber half moon, kitang kita yan
- Feb 2010
- 8
March 1st, 2010 08:25 PM #470gud eve sa lahat, I just went to the mechanic at pina tighten ng mabuti yung clamp pero its all the same. They said maybe it is the injection pump or injector kc napaka usok at walang power ang makina ko. May kinalaman kaya ito sa pagka abnormal diesel consumption nito at sa walang power?
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
