Results 11 to 18 of 18
November 18th, 2011 03:55 PM #11
November 19th, 2011 08:25 AM #12
check transmission. it could be in any gear except Park and Neutral. A/T usually have a Neutral Safety Switch cutting off the Starting/Ignition Circuit if the transmission is not in Park or Neutral. quick check on the cable connections (lever to transmission) may reveal a simple problem. hth
November 19th, 2011 09:13 AM #13
brod, reset mo ang emergency button ng car alarm. nasa ilalim ng dashboard. kulay red yan at maliit lang. anti-theft system ng sasakyan natin yan. sa driver side, may maliit na slide cover ng left side mo, pagbukas mo, kita agad yan. nangyari sa akin yan. sabi ng mekaniko sa isuzu, tranny problem, ayaw ma detect ang park. buti nalang, sabi ng electrician, anti-theft system lang. its always a good thing to ask for 2nd, 3rd opinion.. hehehehehe
November 19th, 2011 09:45 AM #14
in case, di mo makita yong red button na sinabi ko, check your manual regarding anti-theft button, refer to your manual.
November 19th, 2011 09:58 AM #15
guys im sure transmission to.. nag bblink yung CHECK TRANS na icon dun sa dashboard eh.. paano ba tingnan yung sira nito
November 19th, 2011 09:13 PM #16
check the quantity and quality of your ATF.....then
check also the sensor if loose or corroded.....
if everything checks out, a quick scan on the stealership might confirm the problem......
November 20th, 2011 12:25 PM #17
guys naayos na yung crosswind.. may cable lang na natanggal from the transmission ) 200 petot lang bayad
salamat sa lahat ng nag reply
Daming issue ng SU7:grin:
Xiaomi E-Car
