Results 11 to 17 of 17
May 16th, 2010 10:05 PM #11
*benzmizer
correction on my post, I was informed by may dad, the problem was experienced again thursday, although he thought he didnt start the engine properly so he did noticed that the hard starting is back again... Friday, definitely there is a problem as it takes to 2-3 times before the alterra is to start. And just this afternoon is the worst.... it wouldnt start at all after following what the technician mentioned how to start the alterra if hard starting was experience, this procedure was executed but Failed, the alterra doesnt start at all. my father is about to call in the towing service when he just tried to start it for the last time.... and... it did start.. he just went home to be safe and not be bothered by the engine problem... so instead of doing some other walks he just cancelled it and called me later this afternoon to inform me for his frustration on how our alterra was poorly service by isuzualabang.. there is some areas that are being overlooked . For me, this is becoming an Issue now... Im still hoping your Big Guns can do something about it.
Thanks again....
May 17th, 2010 12:38 AM #12
June 26th, 2010 02:23 PM #13
final update on our alterra
Isuzu alabang cannot identify the exact problem. My hunch is that the immobilizer is already busted, and they cannot find a way to identify or test the functionality of the immobilizer when we first encountered our problem during the warranty period. i was told the immobilizer is at around 10k.....
Anyways, we told them to disable the immobilizer(not removed) as it is embedded to the system of alterra according to them
it has been a month, and our alterra is still running and the hardstarting have gone away after the immobilizer has been disabled
- 8
December 20th, 2010 05:35 PM #14Sir, magpapa 15K ako sa ALterra ko, balak ko sana sa Inteco Q Ave pero sa tatlong balik ko dun, di ako satisfied sa service, not sure even kung ano ginagawa nila.
San po ba ok for 15K? Wala pa naman ako reklamo pero yung tunog ng idling di smooth, not sure kung yung belt. 2 years na Alterra ko ngayong December.
Thanks.
December 20th, 2010 08:23 PM #15
- Apr 2017
- 1
April 5th, 2017 12:15 PM #16mga sir good day po..im having the same problem with my alterra 05 matic..the diagnostic scanner reads immobilizer no signal...mga sir hingi lang po ako ng advice kung ano po ginawa nyo to fix the problem...tnx po..
- Mar 2018
- 14
November 26th, 2018 05:26 PM #17Hi Guys! This error is exactly what I am encountering right now. May I know saan nyo pinagawa yung immobilizer issue ng Alterra nyo? Thank you sa sasagot!
