Page 1206 of 1211 FirstFirst ... 110611561196120212031204120512061207120812091210 ... LastLast
Results 12,051 to 12,060 of 12104
    Jan 2013
    #12051
    Hello mga ka MuX.. quick question lang..
    Meron na ba kayong info kung kelan lalabas dito sa pinas yung all new MuX? Yung all new DMax kse lumabas so I expect MuX to follow na.
    Thanks and keep safe.
    May 2016
    #12052
    Quote Originally Posted by homhomnova View Post
    Wala pang balita, kahit spyshots sa Thailand wala pa. Siguro 2021 pa earliest natin makikita.
    Yung 2020 all new D-Max hindi pa dumadating sa Pinas, expected release Q4 of 2020, pero dahil sa covid malamang madedelay rin.
    Feb 2015
    #12053
    Nagpa-engine wash na ba kayo? May kailangan pa bang takipan?
    Jan 2008
    #12054
    Quote Originally Posted by makelovenotwar View Post
    Alternator. Pero wag spray water.. mas ok kung may steam cleaner ka or use water based degreaser diluted with water.. spray spray lang sa engine bay.. punas punaa then buga ng hangin
    Feb 2015
    #12055
    Thanks sir.
    Balak ko pa naman bugahan lang ng tubig. Wag na lang pala at baka may masira pa ako. hehe.
    Dec 2009
    #12056
    Good day. Ask ko lang saan talyer / shop po kayo nagpapagawa ng MU-X ninyo dito sa South - Las Pinas, Paranaque, Muntinlupa is ok po. Thanks po!
    - issue is check engine problem
    - oxygen sensor un error code
    Napacheck na sa Shell Times and oxygen sensor daw ang problem. Gusto ko lang magpa-2nd opinion sa ibang shop na pwede niyo ma-recommend po.
    #12057
    Quote Originally Posted by cyclops_23 View Post
    medyo maiba lang ng konti. parang it's a bit early to have a failing 02 sensor. ilang years or kms na po MU-x ninyo? if you don't mind me asking.
    Dec 2009
    #12058
    May point ka po sir. 2015 model po un unit. Right now ang nalabas na fault code sa Shell ay O2 sensor. Airbag icon 2 days ago ang lumabas sa gauge panel. So looks like wiring po ang problem. Rats in engine bay. May nakitang broken wire po kasi and initial suspect is wiring to the air bag po.
    Jan 2013
    #12059
    Hi guys! Sa mga naka first batch po dito, nagstart na din ba sa inyo magkaroon ng rattling noise every startup? Lahat ng napagtanungan ko sabi nila normal daw since oil hasn't fully circulated yet. Marami din ako nakasabay na first batch mu-X sa parking lot ganun din ang tuno. Pero for the first 4 years of ownership di naman ganun, going 96K Km na pala siya and PMS lagi sa casa.
    Kahit 10 mins pa lang nakapatay engine may rattle pa din, ibig sabihin ba kulang ang oil or masyadong malabnaw para bumaba agad? Mas matagal mag rattle if naka incline siya, nawawala agad pag mas mababa naman ang nose.
    I also just got a new pair of tie rods and rack ends, yung rack ends ok pa daw pero palitan na lang din para isang gawa.
    Sent from my H8266 using Tsikot Forums mobile app
    #12060
    i don't isuzu,
    but that sounds logical naman.
    clearance space between metal parts increases with wear and tear.
    noise without oil to cushion the banging together of the metal surfaces is more notice-able.
    when oil arrives, the oil cushions the metal surfaces banging into each other, and noise becomes less.
    i sometimes hear my valves more, when i start my car that hasn't been used for quite some time.
    after a minute or so, the noise lessens.
All New Isuzu MU-X // Alterra Next Generation
