Results 11,981 to 11,990 of 12114
August 23rd, 2019 05:25 PM #11981
it rides abit stiffer compared to the oem shocks. if you want the soft ride mag oem ka. if you want the slightly stiffer ride bilstein. heres an article about bilsteins replacements..
Road Testing the Bilstein shock upgrade for Trailblazer | James Deakin
August 23rd, 2019 07:26 PM #11982
The Bilsteins are a lot stiffer vs stock bro. 5100's & B6's valving are digressive (great high velocity damping, too much low velocity damping)
On the plus side, it corners with confidence and big bumps and dips are dismissed like they aren't there.
But on smaller rough spots like rumble strips and uneven concrete roads you can really feel everything.
I suggest you try out someone else's MUX with these shocks before you buy them.Last edited by Wh1stl3r; August 23rd, 2019 at 07:53 PM.
August 23rd, 2019 07:49 PM #11983
August 23rd, 2019 08:04 PM #11984
Had to correct myself. Edited the post na. Too much low velocity damping.
It will definitely remove the wallowy ride. And it'll handle a lot better. But in most cars I've driven/ridden with the same family/model (B6/5100) the ride on small undulations is so annoying specially at low speed I either have to fly through them or slow down to a crawl to make it bearable.
I find most twin tube shocks have progressive damping and are easier to live with. You can slow down on bigger bumps or deeper ruts anyway. And on small undulations common on our roads you can maintain a decent speed while still being comfortable.
Best test drive someone else's rig talaga before buying. Mahal din yang Bilstein.Last edited by Wh1stl3r; August 23rd, 2019 at 08:09 PM.
August 23rd, 2019 08:15 PM #11985
- Dec 2008
- 60
BANNED BANNED BANNED
- Sep 2014
- 8,492
August 24th, 2019 12:08 AM #11987gawin nyo na lang kasi 40psi ang gulong ng MUX nya para hinde wallowy, it's wallowy coz 29psi ang nasa pinto, pag sinunod nyo yun masyado boaty and also less fuel-efficient . but the stock Bridgestone tires is max at 44psi.
My rules is always minus 10%. of the max PSI, so 40 psi aka sa blue power.
with my Santa Fe I , also do 40 psi kasi 44 psi din max sabi sa gulong weird coz it's only 235/65/R17
and my wildtrak I also do 40 PSI, coz even of 265/60/R18 Bridgestone sya as compared to my 255/60/R18 Bridgestone MUX, pareho sila max 44psi
My Santa Fe still uses the stock springs from year 2007, never pa nasira , and I just follow that tire rule, less than 10%
pag ang tires optimal ang laman ng hangin, less strain sa suspension coz the tires absorbs the imperfections of the roads. it acts as a backup suspension, yun goma. I learned that somewhere in the net some 5 years ago
mas mura naman gulong noh, kaysa suspension parts.
August 24th, 2019 06:52 AM #11988
Agree ako sa mas mataas na tire pressure para mawala o mabawasan un wallowy ride. 35psi naman ako.
Un kyb skorched4 shocks ok kaya para sa mux?
Sent from my Redmi Note 5 using Tapatalk
- Aug 2008
- 498
August 24th, 2019 07:15 AM #11989
- Sep 2014
- 8,492
August 24th, 2019 02:05 PM #11990Ang napansin ko kasi dyan sa mga pahanginan sa gas station like for example sa shell , if you load like 40 psi , check after 3 days and your tire pressure is ranging 38 to 39 psi.
It’s either the pump is miscalibrated or yun hangin mismo nila is substandard. I dont load nitrogen kasi eh. One observation ko lang if sa ok na vulcaniizing shop ka nag pahangin consistent ang 40 psi for like 2 weeks or so. So malamang may impurities ang mga gas stations, well what can we expect libre, saka kung sino-sino lang naghahangin dun
I dont have TPMS in my cars, pero I check the tires everytime I leave, after years of doing it, ma train naman eyes mo as well as konting pindot if your tires are in good shape, basta you are parked in a flat pavement like for example mall or condo parking.
Yun kasi 35 psi , im not comofrtsble with it, although 35 psi is the most comfortsble, kumbaga para ka naupo sa cushy sofa vs sa 40 pai na sofa na may thin layer lang ng cushion
So there you have it, pag ultra comfortable na ang car sa kin, thats the time pahangin na ako. Besides you ll never know when you have 4 to 7 passengers, so better be laging handa. Those extra weight can exact a great toll sa suspension pag sobra baba psi.
